lt1 heads on a sbc
Old Feb 10, 2006 | 11:35 PM
FLIPPINZ28's Avatar
lt1 heads on a sbc
Can 94 lt1 heads be used on a vortec block with a diffrent intake of course. Just wondering if the heads have to be reversed flow. Thanks
Old Feb 11, 2006 | 01:09 AM
1racerdude's Avatar
Re: lt1 heads on a sbc
No-- The heads ARE reverse flow the block is NOT.
Old Feb 11, 2006 | 01:28 AM
96m6lt1's Avatar
the heads require welding and drilling but for the 100.00 you will pay for the work and the 200.00 for the heads do it go here to see how its done www.thirdgen.org inside go to TPI there is a sticky
Old Feb 11, 2006 | 01:58 AM
1racerdude's Avatar
Ya could use conventional SBC heads and they are a dime a dozen out there. The LT1 head is not the best flowing head by a long shot and to re do them back to conventional SBC is a waste of money and time IMO.
Old Feb 11, 2006 | 03:54 AM
Ray86IROC's Avatar
Just us the L31 iron Vortec heads, they're very very similar to the iron LT1 heads but for a conventional SBC. They outflow the Aluminum LT1 heads by a fair bit stock. If you're running a hot cam with over about .470 lift you will want some better vavle springs and a quick clearance job on the valve guides though.
But anyway you'll likely make more power w/ Vortecs than you would w/ the stock AL LT1s... You can get a set on ebay for about what LT1 heads go for.
I was running box stock Vortecs on the 350 in my 87Z, w/ a 218/224 cam, edelbrock headers, etc. There is no doubt it would annihilate my current bolt on LT1...
Old Feb 11, 2006 | 08:18 AM
96capricemgr's Avatar
The Vortecs do outflow the early LT1 aluminums not by a huge amount but do outflow them enough to make pulling the Vortecs and modding LT1 aluminums to fit nothing but foolish.
Old Feb 11, 2006 | 03:47 PM
FLIPPINZ28's Avatar
Thanks, That is what i was explaining to my buddy but he didnt believe me. So I had others now that say the same. Thanks Guys
oldschool
Feb 9, 2016 09:21 PM
Steve69SS396
Track Kill Stories
15
Aug 10, 2015 02:45 PM
InfernalVortex
Jan 17, 2015 09:35 AM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
