lt1 headers installed
Old Apr 15, 2007 | 03:39 PM
lt1 beast's Avatar
finnally got my long tubes installed after struggling to put them in from every which way...i lifted the motor from one side at a time..now im concerned that i may have tore the ground wire off of the blockcausing it not to start...im tryining to norrow down the possibilities..any input would be greatly apreciated
Old Apr 15, 2007 | 03:52 PM
lt1 beast's Avatar
oh and by the way the car has a new coil, msd wires, and gm distributor installed correctly
Old Apr 15, 2007 | 04:48 PM
12345678910's Avatar
did you do all that at the same time and it didnt start or did it not start just after the header install
Old Apr 15, 2007 | 05:09 PM
MEAN LT1's Avatar
Well...check and see if you busted the wire or not?
Old Apr 15, 2007 | 06:28 PM
2000GTP's Avatar
What happens, does the car at least crank, but just won't fire? Seeing that you replaced several components of the ignition system, I would still give it a look over once again.
Old Apr 15, 2007 | 09:28 PM
96redrum's Avatar
Not trying to steal ur thread but what r the odds i'm having the same problem u r, did the same mods LTheaders, opti, wires, coil, and wont start, but when i unplug the mas air flow, car will start after a few cranks but sounds like im trying to start a high compression motor and dies if i let of the gas, even drove it around the block and drove like s%#t
SpeedJunkee
Dec 9, 2014 10:17 PM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
GigaMp3z
Feb 20, 2003 02:57 PM
