LT1 Header Bolts: Which length???
Old Apr 20, 2005 | 08:22 AM
  #16
White Knight 95's Avatar
Re: LT1 Header Bolts: Which length???
When I was installing my AZS&M headers, there were a few primaries that I could not fit a 1" bolt around. Obviously, go with 1" when you can, but use 3/4" when you can't.
Old Apr 20, 2005 | 05:16 PM
  #17
bt96ss's Avatar
1 inch Breslins here. They are high priced but went I ahead and bit the bullet and ordered them. Now after installing them I willl never use another header bolt again. I used to have regular bolts back out all the time. I've heard friends complain about the stage 8 locking system. These stay tight. I rechecked them one time after installing the headers and haven't touched them again.
Old Apr 20, 2005 | 07:22 PM
  #18
RedRyder518's Avatar
Which bolts could you not get them in? I think the hardest one was the second bolt on the #2 primary. That is definitely the hardest to tighten as well!
Normally the primary is too close to the bolt to get a good 12 point wrench on it but for some lucky reason, when I bought a new 12 point Craftsman wrench, the closed end was offset just enough when it was manufactured that I can fit the wrench on the bolt and tighten it pretty good. Talk about lucky!!
Old Apr 21, 2005 | 07:47 AM
  #19
I can't remember off the top of my head which ones were giving me grief, but the problem was with getting the bolt threaded, not tightened. A few times, the 1" bolt was just a bit too long and I couldn't get it threaded without fear of crossthreading. The 3/4" slid right in there. The stage 8's are nice b/c they have the tiny little head that you can tighten with an allen wrench, making installation and adjustment much easier.
Old Apr 21, 2005 | 08:42 AM
  #20
Mystic97Z's Avatar
i ordered some from cmotorsports last week, arp 12 pt.
i think i might have gotten the 3/4 "
u guys talking 1" total length, or 1" of threading?
i need to go home and check,,,maybe need to get the longer ones..
-Jason
Old Apr 21, 2005 | 09:06 AM
  #21
got_hp?'s Avatar
-Jason
i use ARP 12pt with 1" of threading and 5/16" head on my jethots (thick flange), part # 100-1209 in black.
the 5/16" head makes it easier to get a wrench on it next to the header primary. i still have to grind the head of my wrench though, thanks to jethots totally crappy design of their headers, they should have indented the primary to give the bolts more room. jethot headers totally suck.
ive used Stage8, and Breslin already, and so far the ARP's are better. they both had fitment problems, the heads of the bolts were too big to fit next to the jethot primary, and could not get a wrench on them, and the allen key on the stage8s kept stripping. one of the breslin bolts actually broke in half.
Old Apr 21, 2005 | 04:37 PM
  #22
94zgreenmachine's Avatar
-Jason
Generaly when you are talking bolt length, it is the threaded section. You should have 7/8 inch of thread in the head. With a flange and gasket 1" is good and will give you more thread contact than a 3/4 inch bolt. Especially being Aluminum, this is more threads "grabbed" the less chance of stripping. And that would suck!
Old Apr 25, 2005 | 11:49 AM
  #23
Mystic97Z's Avatar
i just called combination motorsports and they don't carry any 1" arp header bolts,,where can i get some?
Old Apr 25, 2005 | 04:14 PM
  #24
www.summitracing.com
ARP part 400-1209
type that in the part # lookup. They are stainless steel and are $28.69
I love summit Jegs sux!
redleader
Parts Wanted
Nov 13, 2016 02:57 PM
oldschool
Feb 9, 2016 09:21 PM
redleader
Jan 22, 2015 12:05 PM
Jason Short
Jan 19, 2015 06:34 PM
The Seer
Classic Engine Tech
Nov 26, 2014 05:55 PM
