LT1 Header Bolts: Which length???
Old Apr 19, 2005 | 06:52 PM
snausman's Avatar
I'm getting some Stage 8 Header bolts, but need to know which length. They're going in a '96 LT1 with Pacesetter headers.
thanks!!
Ross
Old Apr 19, 2005 | 07:18 PM
jkipp84's Avatar
Re: LT1 Header Bolts: Which length???
I use 3/4" ARP's, but they don't have all the wacky locking stuff the Stage 8's do. 1" might be better for those? Hopefully someone with them will chime in..
Old Apr 19, 2005 | 08:57 PM
MarkyMark's Avatar
I used the 1 inch long 12 point ARP Header bolts on mine.....work pretty good.
Old Apr 19, 2005 | 09:09 PM
Scream And Fly's Avatar
I have the 3/4" Stage 8 bolts. A bit of a PITA to play with though.
Old Apr 19, 2005 | 09:28 PM
94zgreenmachine's Avatar
thanks!!
Ross
A good "rule of thumb" is to have at least bolt diameter plus an 1/8 inch of thread in what you are blolting into. Being aluminum I would want every thread to grab. Get the 1" length. There is approx. 7/8 of thread in the head
Old Apr 19, 2005 | 09:52 PM
got_hp?'s Avatar
GET 1 INCH !!!
im not sure about pacesetters, but jethots have a very thick flange, and with the 3/4" bolts, there are only a few threads actually gripping the head, and it makes it very easy to strip.
Old Apr 19, 2005 | 10:04 PM
chevyguy3's Avatar
i have used 3/4" ARP on many LT1's with headers. a few installs ago i started using 1" and they definitly dont come loose near as often as the 3/4" do (no-brainer if you stop to think about it).
tried stage 8's once on a customer's car on thier insistence. those things are more of a PITA than its worth. next time i had to work on it i trashed them and went back to ARPs
Old Apr 19, 2005 | 10:14 PM
CamaroBoy96Z28's Avatar
I use the same.
Old Apr 19, 2005 | 10:29 PM
1997Z's Avatar
The owner of the shop that installed my Jet-Hots used 3/4" Stage 8's. Dumbass. They backed out. I am now using 1" Breslin Stainless. I have had no problems...
Old Apr 19, 2005 | 10:32 PM
Bawls's Avatar
Thats what I'm going with from teh get-go. Breslin all the way.
Old Apr 19, 2005 | 10:37 PM
93LT1355's Avatar
Definatly go 1 inch
Old Apr 20, 2005 | 12:02 AM
atljar's Avatar
1 inch for pacesetter or jethot
3/4 inch for hooker LT
Old Apr 20, 2005 | 12:07 AM
RedRyder518's Avatar
I have 1" stainless steel Breslin's. Havn't had them back out They are kind of a pain in the *** with the AS&M's with a couple of them, but I can usually retighten them all within 30 minutes.
Old Apr 20, 2005 | 12:08 AM
94heritageZ's Avatar
What size for MAC mids for a LT1 ????
Old Apr 20, 2005 | 04:55 AM
Try the Hookers with a percy dead soft gasket. You have to run a 1 inch just to get the bolt to grab at all. At first, I thought I got 4 gaskets when I bought them.I was wrong, the gasket is just that thick.
