LT1 head question
Old Mar 12, 2003 | 12:54 PM
ryaskovic's Avatar
LT1 head question
Are the large oil drain passages (one at front and one at the back of each head) the ONLY oil passages in the head?
Is there any oil passage between the block and the head, or are all the holes for coolant or bolts?
Reason I ask: It seems that I've got oil seeping from the head gasket under the #1 and #8 cylinders.
Thanks,
Rob
95Z28
Old Mar 12, 2003 | 01:05 PM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
I dont believe thre are any Oil passages for the heads from the block. I want to say the draining is at the rear but i'm not sure- i forgot. I have some Lt1 head blue prints on my computer, i'll check it out for ya, but those things have a bazillion lines...
Old Mar 12, 2003 | 01:26 PM
treyZ28's Avatar
looking at the blue prints-
there is ont at the front and rear i think-
i'll post pics in a min
Old Mar 12, 2003 | 01:38 PM
treyZ28's Avatar
http://www.worldisround.com/articles/15303/photo2.html
the things in the corners look like them
FIXED LINKY
Old Mar 12, 2003 | 02:59 PM
ryaskovic's Avatar
Yep, those are the ones I was referring to. Cool pic! They actually drain into the lifter valley so I'm wondering how I'm getting oil down at the head gasket under the #1 and #8 exhaust ports. If there are no other oil passages.....hmm.
I don't think it's coming from the head bolt holes. Those are either blind holes or run into water jackets, correct?
Somehow oil is leaking down there. Maybe I have to take a much closer look at the intake manifold to head junction and make sure it's not running down from there. That would make more sense to me. I've looked several times at the block to intake manifold junction (where it's common for LT1s to leak) but that looks dry.
Rob
95Z28
parkers Z28
Mar 11, 2016 08:14 PM
oldschool
Feb 9, 2016 09:21 PM
LT14LIFE
Feb 9, 2015 09:35 PM
HectorM52
Parts Wanted
Jan 10, 2015 09:01 PM
Geoff Chadwick
Jul 31, 2002 12:07 PM
