LT1 has no power and makes clacking noise
Old Jan 27, 2003 | 07:41 PM
  #16
Se7ix's Avatar
You cannot run 87 octane fuel in an engine with a 10.5:1 compression ratio. You MUST run 93+ or you can cause serious damage long term.
What you may be experiencing is severe timing retard to compensate for knock (detonation).
Old Jan 28, 2003 | 12:57 AM
  #17
Ryan's Rod's Avatar
Thanks guys. I'll fill the rest of the tank with Supreme and see what happens. I should've known better. Even if this isn't the full problem it's gotta be one of them.
Old Jan 28, 2003 | 05:35 AM
  #18
magius231's Avatar
I would put unleaded high octane racing gas in the rest of the tank and see if it goes away...if it does, try running premium and see if it stays gone, if not you have some detonation issues...
F'n1996Z28SS
Aug 23, 2023 11:19 PM
siguy
Nov 27, 2014 10:07 AM
