LT1 Guru's inside ... Need Help ASAP
Old Aug 4, 2003 | 05:39 PM
  #16
JOE96Z28SS's Avatar
22 Ohm Resistor Just so you don't blow the LED I believe radioshack sells LED's that take 12 Volts, also LED's will only light when the polarity is right
Old Aug 4, 2003 | 10:26 PM
  #17
HardcoreRM125's Avatar
Messed around all day with Multi-meter and had my uncle who is mechanic come down to gimme a hand. Traced wires back to the fuse panel , swapped out the Relay for the Air Pump and now the Noid Lite lit perfect everytime on all 8 cylinders , so now their getting the signal , i just have to get my cousin to bring his injector cleaning set-up down , clean em and it SHOULD fire right up ...
Sergio
Jan 27, 2016 04:27 PM
Redbird
Sep 14, 2002 09:18 AM
Redbird
Aug 2, 2002 06:50 PM
Redbird
Jul 29, 2002 06:23 PM
Redbird
Jul 20, 2002 06:08 AM
