The LT1 is going in this weekend. Just a few quick problems I need to resolve
Old Mar 30, 2003 | 04:41 PM
Chuck2's Avatar
Ok the 3.4L is ready to come out and the 1996 355 Lt1 is 95% ready to go in. The few concerns that I have are
1. I have read that the vent tube off the optispark goes to the intake. Where does it hook up on the intake at?
2. On the throttle body, the two lines that flow coolant didnt come with the engine so i dont know where they run to. I looked at my step bros 93 Lt1 and the one that flows coolant into the TB comes from a formed heater hose and the outlet hose goes down to a connector on the lower radiator hose. My radiator hose doesnt have this nor do I have this formed heater hose.
3. The wire loom that runs down to the starter has a black wire and a purple wire. THe purple one runs to the coil and I believe that the black one is a ground. From what i understand this black wire grounds on the spark plug holder. Hopefully someone can comfirm this.
Any help with these 3 problems will be appreciated Thanks
Old Mar 30, 2003 | 06:04 PM
n2oCamaro's Avatar
The vent tube for your opti connects to the intake elbow (the piece that connects to the throttlebody)
Old Mar 30, 2003 | 06:30 PM
Mtrhds94Z's Avatar
The hose configuration is different for a 93-4 than for 95-7..
Look at these, from shoebox' site...
http://csce.uark.edu/~jgbertr/rb/93-94_hoses.jpg
http://csce.uark.edu/~jgbertr/rb/95-97_hoses.jpg
You most likely want the 'late' configuration..
Also, if you want the TB 'bypass' take hose '5' and hook right to the 'steam pipe' [bypassing the TB]
Charlie
Old Mar 30, 2003 | 06:53 PM
DiabloZ's Avatar
Don't worry about running coolant through the TB if you don't want to. Most peolpe bypass it and hook the two lines into one anouther and skip going though the TB in hopes of keeping it cooler and gaining about 7hp.
If you don't have the hoses don't worry about it.
Old Mar 30, 2003 | 07:25 PM
anasazi's Avatar
connect hose 5 to hose 6 for the TB bypass
i think those were the numbers... that diagram is hard to read
Old Mar 30, 2003 | 08:47 PM
DiabloZ's Avatar
He don't have hose 5 and 6. He is swapping tit into a v-6 car and using the v-6 rad. and hoses. (Questionable on the cooling effectiveness for the v-8)
Old Mar 31, 2003 | 06:02 AM
Mtrhds94Z's Avatar
As I said, take hose 5 and connect directly to the 'steam pipe' that goes to rear of head..[ no 'connector' needed for 95-7 configuration..]
If you don't have LT1 radiator I suggest getting one[ for the 'bypass' hose etc.]
Old Mar 31, 2003 | 11:39 PM
Chuck2's Avatar
no Ive got Lt1 radiator and hoses but i dont have the coolant hoses running to and from the TB. THat diagram helps out quite a bit. Ok Ive got the optispark vent and the TB coolant lines figured out. Anybody know anything about the wire near the starter?
D1SC383LT4
Jan 1, 2016 01:56 PM
David Dorris
Jan 17, 2015 08:10 PM
97SSdude
Dec 31, 2014 07:43 PM
Jazsun
Dec 29, 2014 12:14 PM
1LEThumper
Jul 14, 2003 12:45 PM
