LT1 fuel pump?
Old Jul 16, 2009 | 09:48 AM
Greg Nolte's Avatar
LT1 fuel pump?
I have a 69 with a 95 LT1. It's my understanding the stock pump is 43 psi.
I've been looking at a the GM32BFI tank. It comes with a 85-115 psi 50-60gph pump.
WIll this work?
The engine is stock.
Old Jul 16, 2009 | 12:19 PM
Kevin Blown 95 TA's Avatar
That'll work because you are going to regulate the fuel pressure down to ~43 anyway - The stock LT1 pumps will make higher pressures like that too if you clamp off the return line so its not like the LT1 pump only makes 43#, that's just what it's regulated at. You can't put 100# to your injectors, at least not for very long.
BADAZZ_Z
Parts Wanted
Mar 5, 2019 12:55 AM
Gtpguy
Jan 26, 2015 04:50 PM
FIREBIRDMARK1
Jan 7, 2015 03:36 PM
ANDYZ28
Dec 29, 2014 09:13 PM
