LT1 four bolt mains?
Old Oct 21, 2003 | 10:31 AM
  #16
jgeorger's Avatar
I wish GM was still making LT1 blocks.....
One thing not mentioned here - I was told that the splayed mains would interfere with the dipstick tube. My shop convinced me to go with the straight 4-bolt. I know some people have got it to work, but it seemed like it took some work in all cases.
Old Oct 21, 2003 | 10:51 AM
  #17
rskrause's Avatar
Moderator
Originally posted by Injuneer
The GM 4-bolt block is excellent for a high performance engine... you just need to add billet caps. George Baxter used the straight 4-bolt GM block for his 1,125HP 9.04-second LT1 setup. When the engine was torn down, it was in excellent shape, and the block is being reused in an 1,100HP nitrous setup. I wouldn't be so sure that a "splayed" setup is any stronger than the factory straight setup. Remember... the factory knew they were going to a 4-bolt design, and put the strength in the block to support the straight configuration.
Agree! Current setup: 876rwhp (through a TH400 and 4,200 stall converter) with GM nodular iron straight caps.
Rich Krause
Old Oct 21, 2003 | 03:58 PM
  #18
Josh-'04 GTO's Avatar
No one said that the straight 4 bolt couldn't handle alot of power. But the splayed setup IS stronger due to the fact that the outer bolts tap into a MUCH stronger portion of the block than straight 4 bolts do. Plus the angled bolts coupled with the 2 straight studs help provide more dimensional stability vs. 4 straight studs. But I guess that this discussion is like a chat about Ferrari vs. Lamborghini....you can't go wrong either way!
Considering the power levels that most board members see with their motors, straight vs. splayed probably isn't an earth-ending decision anyway.
HectorM52
Jul 30, 2017 11:46 AM
importkiller94
Parts Wanted
Jan 17, 2015 07:23 PM
ddr698
Jan 9, 2015 10:05 AM
97 RedSS
Jun 10, 2003 07:58 PM
