LT1 F-Body Cooling System vs. B Body
Old Aug 14, 2012 | 05:03 PM
tylerwerrin's Avatar
Hi guys,
I blew my head gasket last week after cruising around out in the Inland Empire -- I didn't fully overheat, but i think the gasket was getting ready to go -- noticed some weird performance issues and a leakdown/compression test sealed the deal.
I was puzzling over why the head gaskets would blow -- i had a new water pump, new gaskets, 160 thermostat, fans tuned to come on much earlier as well as an all aluminum multi core radiator.
I used to have a B-body engine in my car before it spun a bearing -- i had mimiked the B-body cooling system by integrating a pressurized coolant tank, vs the F-body system which has no tank. When I swapped in the Camaro engine last year, I kept the cooling system because I already had the parts, and it was essentially new.
Is using a B-body system with a coolant tank possibly to blame for the overheating of the engine? I was thinking GM designed the system for the F body with the integrated cap on the radiator with the Aluminum heads in mind, but is there actually an engineering reason? I want to know before replacing the heads if I need to get a new radiator, water pump & fan setup.
Thanks!
Old Aug 14, 2012 | 05:14 PM
Re: LT1 F-Body Cooling System vs. B Body
The Y-Body (Corvette) LT1 has the elevated, self-purging, pressurized reservoir (not sure if identical to the B-Body), and they use aluminum heads. The Y-Body system is designed to eliminate the problems of purging the air out of the system. Sounds like the B-Body might have got the same system. The lowly F-Body got short-changed.
The next question would be whether the system was configured properly, when it was integrated with your 94.
Old Aug 14, 2012 | 06:24 PM
I didn't realize the Y-body had a pressurized coolant tank as well. That is good to know that I can keep the same system.
When i mated the systems I used the same configuration as the B-body -- same water pump, same coolant reservoir tank, etc. I can't recall exactly where each hose went off the top of my head, but it was put back together the same way as it was set up with the B-body engine. I can take some photos later, but I think it's OK. Maybe it was just time for the gasket to go -- it was hot out in the desert.
One other cooling question, perhaps I'll have to show a picture -- but I mated the dual fan assembly to the corvette radiator with 4 bolts. The camaro fan assembly clipped right to the radiator. Perhaps my fans need to be "blocked off" so the air rushes through only the radiator and not anywhere else.
HectorM52
Jul 30, 2017 11:46 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
