LT1 Engine Swap
Old Oct 31, 2006 | 05:46 PM
LT1_King's Avatar
LT1 Engine Swap
will a LT1 out of a 96 Z M6 fit a 94 Z A4? the reason i was asking is because i found a motor for a good price and i wanted to swap it out. what would i need to do would i have to just switch my computer out with it or will it not work with the motor? the thing that i'm concerned about is that the new motor had a M6 and mine is an A4. need help ASAP.
Old Oct 31, 2006 | 06:12 PM
Dave89IROC's Avatar
use your computer/harness, engine sensors(leave the crank sensor in the 96 timing cover, no need to plug anything in to it) and trans/flexplate
you might need to remove the piolot bushing from the rear of the crank(for the MT), no biggie
Old Oct 31, 2006 | 06:25 PM
LT1_King's Avatar
i thought it was going to be more of a hassle because of the difference in trannys.
Old Oct 31, 2006 | 07:26 PM
Dave89IROC's Avatar
nope, engines are identical
rocketman051894
Jan 30, 2015 03:23 PM
InfernalVortex
Jan 17, 2015 09:35 AM
cmdeshon
Jan 4, 2015 11:15 AM
Ricardo
Nov 29, 2014 10:58 AM
Jul 4, 2005 05:00 PM
