lt1 engine rebuild
Old Nov 24, 2008 | 01:29 PM
heavychevy09's Avatar
lt1 engine rebuild
might be better in the LT1 tech section, but im looking for a quick answer. what would a basic rebuild cost for an lt1? including machine work, gaskets, maybe some headers. looking for a ball park figure
Old Nov 24, 2008 | 01:36 PM
mdenz3's Avatar
$700B
Machine work will depened greatly on where you live, gasket and header prices can be found easily on Summit's website.
Old Nov 24, 2008 | 01:48 PM
AZ2ENVY's Avatar
That is such a broad question it honestly depends on the quality
of the build , builder , parts quality , and what you wanna skip on
Old Nov 24, 2008 | 01:58 PM
well, it would be a stock rebuild, reuse stock crank, cam, pistons/connecting rods, probably new rockers/pushrods. headers i figure about 200-300
Old Nov 24, 2008 | 01:59 PM
6spdpewterZ's Avatar
will you be changing the drive shaft?
Old Nov 24, 2008 | 02:01 PM
so long as i dont cut it i think it'll be ok
Old Nov 24, 2008 | 02:08 PM
confused327's Avatar
If the head and deck are close enough to flat and the rest of the engine is in pretty good shape, no spun bearings or scored crank or deep scratches in the cylinder wall, you could probably do it for $500. That's assuming you do just about everything yourself, and just get the block tanked/honed.
Old Nov 24, 2008 | 02:26 PM
mdenz3's Avatar
A Re-ring kit alone is $330 So it could be done for $500, but barely. To do a standard rebuild I would geuss in the $2000 range.
EDIT: If you do do it alone I have .010" under rod and main bearings and 9966 headgaskets I could get you a great deal on.
Old Nov 24, 2008 | 02:27 PM
BassProCamaro97's Avatar
It really depends on what went wrong.
Chances are if you are needing a rebuild its going to cost you more than 200-300 dollars.
Machine work generally is not cheap. Plus you never know what else could have gone bad after the intial failure.
~Jim~
Old Nov 24, 2008 | 02:31 PM
as far as i know, nothings failed, just looking to freshen it up before any bolts on or anything
Old Nov 24, 2008 | 02:34 PM
Tokuzumi's Avatar
You might be better off getting a remanufactured engine. They cost between $1500-2000+. And they come with a guarantee.
Old Nov 24, 2008 | 03:16 PM
For a standard 4" bore? I think I paid sub-$100 for rings for a SBC, unless LT1's take completely different rings.
Old Nov 24, 2008 | 03:25 PM
mdenz3's Avatar
by "Re-ring kit" I ment with all the gaskets and bearings.
Old Nov 24, 2008 | 03:27 PM
JasonD's Avatar
Admin Emeritus
Who looks for slow answers? Please post in the proper forum. Moved.
Old Nov 24, 2008 | 03:32 PM
Oh, that sounds about right then.
$2000 for a GOOD rebuild sounds right as well, but assuming nothing major is wrong a $500 rebuild would get you going again. But if nothing major is wrong, why rebuild it?
