LT1-edit
Old May 13, 2005 | 01:01 PM
'94 Red Dragon's Avatar
LT1-edit
I know this program will allow you to tune your PCM but can you also tune your ECU like the hypertech powerprogrammer will do.(air/fuel ratio,shift points,rev limiter,top speed limiter,etc.) I'm a little confused about this.
Old May 13, 2005 | 01:08 PM
breakmyfootoff's Avatar
Re: LT1-edit
LT1 edit will enable you to do most of the stuff the mail order tuners can do. The main difference is the fact that those guys have alot of experience in setting up programs for different combo's and they can get fairly close without seeing the car.
Old May 13, 2005 | 01:39 PM
kainZ's Avatar
Re: LT1-edit
Where can we get LT1 edit?
Old May 13, 2005 | 02:44 PM
Re: LT1-edit
go to www.carputing.com I believe they are the only place that sells it. They also created it. There's lots of usefull info on thier site.
Old May 13, 2005 | 07:21 PM
Re: LT1-edit
But after I buy this program can I tune my ECU and PCM both and change engine parameters like a powerprogrammer.
Old May 13, 2005 | 07:29 PM
Re: LT1-edit
Look on the website posted above, they can explain it far better than I can.
Old May 13, 2005 | 08:24 PM
Silver's Avatar
Re: LT1-edit
Yes, but keep in mind, you don't know what the Hypertech guys know. You wouldn't know what to change (and wouldn't want to use their program anyway based on what I've read). You can really screw stuff up if you don't know what you're doing.
But to answer your question - yes.
Old May 13, 2005 | 08:38 PM
rskrause's Avatar
Moderator
Re: LT1-edit
ECU = engine control uint = PCM = powertrain control module
They are two terms for the same thing.
Rich
Old May 14, 2005 | 12:58 PM
Re: LT1-edit
I should be able to do everything that a powerprogrammer can do.
right?
Old May 14, 2005 | 01:04 PM
AF96Z28's Avatar
Re: LT1-edit
with the proper knowledge, you control just about everything the pcm does on that car. Personally, I use Tunercat. It's a personal preference, and cheaper than LT1 edit. What I did, was get a mail order tune from MadZ28.com, then tweak his tune on the dyno. It all comes down to doing what you're comfortable with.
Old May 14, 2005 | 04:56 PM
97FormulaWS-6's Avatar
Re: LT1-edit
It does much much more than that PP POS does.. it just takes more knowledge on how to do it. It's not just as simple as picking which options you want "improved".. it's more detailed in the programming of the computer.
Old May 14, 2005 | 06:11 PM
Re: LT1-edit
Where can I learn this knowledge and what kind of program do i need to do it
Old May 14, 2005 | 06:32 PM
96ta(nick)'s Avatar
Re: LT1-edit
Good luck i am still trying to learn EDIT, It is like learning a foreign language. lol
I have it and all i have done is load my mail order tunes, havent touched the tables.
Henson071
May 15, 2011 02:29 PM
camarohg
Nov 4, 2006 06:57 PM
sean-k94z
Jul 11, 2006 07:02 PM
ss97dml
Jul 8, 2005 08:50 AM
eduncan911
3rd Gen / L98 Engine Tech
10
Oct 29, 2002 01:28 PM
