LT1 distributor conversion
Old Jun 15, 2008 | 12:35 PM
  #16
MarcR94v6's Avatar
Originally Posted by Rich2279
Generally, guys with pre LT1s do this as a performance upgrade. They use their Gen 1 block and heads and have a LT1 intake drilled and modified to fit. I haven't considered the thought of someone changing their Optispark setup to a regular old style distributor.
The benefits I see are: ease of unmaintained with the distrubtor, cap and rotor, plug wires, piece of mind from keeping it out of moisture. The cons I can think of are mostly pcm issues that could potentially not make it smoggable, could be wrong about that last part.
Old Jun 15, 2008 | 06:55 PM
  #17
neil350's Avatar
Your right on the last part, your going to run in to issues with the egr valve, it would have to be removed for clearance on the new crab style. No egr = no pass, even if it wasnt sniffed and had to pass visual, unless the inspector is Ray Charles or doesnt know what their looking at it, it'll fail.
Old Jun 15, 2008 | 07:10 PM
  #18
Rich2279's Avatar
LMAO about Ray Charles. The egr does have to be removed from everything I've read. Not sure how one would get around the emissions testing.
Old Jun 15, 2008 | 08:18 PM
  #19
MarcR94v6's Avatar
lol x2
Damn, that's a shame. Thanks for clearing that up, though. Could still be useful to someone with a track only car or that is lucky enough to "know people".
Old Jun 16, 2008 | 07:19 AM
  #20
Rich2279's Avatar
Originally Posted by brand-x
Does anyone know where I can get my intake converted for a distributor? Also, does anyone know if Scott at www.lt1intake.com is still in business?
I saw this intake for sale over on third gen.
http://www.thirdgen.org/techboard/en...?highlight=lt1
Old Jun 16, 2008 | 10:02 AM
  #21
brand-x's Avatar
Originally Posted by Injuneer
What PCM are you going to run? Did you move the optical module to the new distributor?
I run a gen-7 and the distrib is an accell dual sync....
CT
Old Jun 16, 2008 | 01:08 PM
  #22
GMRL's Avatar
I was thinking of doing this on a third gen Fbody. Swap the TPI engine for an LT1, and just run it with the TPI computer with a prom reburn.
Old Jun 16, 2008 | 06:00 PM
  #23
CT
Without posting that info up front, you've got a lot of people thinking all they have to do is swap in a conventional distributor, and their LT1 PCM's will work..... which of course we know they will not.
Old Jun 16, 2008 | 08:32 PM
  #24
brand-x's Avatar
Oops! That wasn't my intention. I started the thread to see if anyone could direct me to someone who could modify my intake and it morphed into me doing the work myself; just wanted to share the experience and assure folks it wasn't that hard to do if they decided to dothe same.
Old Jun 16, 2008 | 10:12 PM
  #25
JD311's Avatar
couldn't you use like an old gutted sbc points or small cap TPI distributor (or aftermarket) and still use the optispark without the rotor and plug wires. sorta like a crank trigger? I have also seen a billet cover for the opti when you use a coil pack conversion. I thought about this cause a buddy of mine has a 94 impala ss that is totalled and a 64 impala ss 283 powerglide. He wanted me to put the Lt1 and trans with computer and all in the 64, maybe even rear and brakes. He wanted to kinda keep it "retro" looking with the original valve covers with adapters and paint it old school chevy orange. I thought " why not use the old points distibuter and gut it set it up like a crank trigger" put it up on number one and phase it then put it in. We build racecars and all , so I thought it would work. Take all the spark energy away from the "actual" distirbutor.
Old Jun 16, 2008 | 11:19 PM
  #26
Sure... the Delteq and Bailey LTCC multi-coil systems for the LT1 use the Opti optical sensor as a cam position sensor. I use it to feed a MoTeC M48Pro with an 8-channel ignition driver. The advantage of keeping the spark timing in the PCM (vs. the "old school" distributor) is the ability to program advance, without playing with weights and vacuum diaphragms. In the setup mentioned by the original poster, he's using the dual-synch distributor to achieve the same results. But some aftermarket ECU's like the MoTeC, with run off the Opti signals, and provide very high precision ignition timing.
Old Jun 17, 2008 | 02:34 PM
  #27
383ysi's Avatar
cant see the pics
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Queens94z28
Dec 20, 2014 09:11 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
