LT1 db levels - help me reduce them!
Old Jun 10, 2005 | 04:55 PM
FastWhiteTA's Avatar
I failed the noise levels for my emissions test. I have SLP shorty headers w/ a carsound 3" hi flow cat and a brand new hooker catback system. I have a couple questions...how can I make the system more quiet?? If I take off the dual tipped hooker tips and have just single tips, does that make a difference? Maybe if I temporarily replace the hooker tips with some crappy smaller diameter tips, would that quiet the engine down enough? I am at 99dB and I have to get alllll the way down to 93dB. That's a big step. ANY help would be greatly appreciated! Any other ideas besides replacing the entire muffler just to pass sound levels???
Thanks.
Old Jun 10, 2005 | 05:31 PM
Kraest's Avatar
Retired
Re: LT1 db levels - help me reduce them!
Potato in the tailpipe
Old Jun 10, 2005 | 08:19 PM
2cub49's Avatar
Striaight through bullet or twister bullet in the I pipe.
The twister will definately do it by 10 db. Then you can take it out.
Old Jun 10, 2005 | 08:40 PM
94zgreenmachine's Avatar
I believe it is dynatech that makes a perforated cone called the vertex. Summit sells them.The weld in the collector and they are a perforated cone with the surface area of the cone equals to approx. 3.5 diameter so virtually no backpressure is developed, yet it quiets the exhaust note. I welded one in each collector,(you can also bolt them in) and my car no longer sounds like a winston cup car( Nextel sounds to weird and gay).
NorthPoleDev
Dec 31, 2014 03:20 PM
AlaskaZ28
Dec 10, 2014 02:37 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
teedoff59
Aug 8, 2002 01:36 AM
