LT1 computer issue, no fuel
Old Oct 25, 2013 | 07:58 AM
92rslt1's Avatar
What would cause an lt1 fuel pump not to prime or operate?
If I jump the relay it will work, however the pcm is not telling the pump to turn on. I am trying to chase this down, I think any sensor would prohibit the fuel pump from priming, but I could be wrong.
Old Oct 25, 2013 | 09:23 AM
pizzi-man's Avatar
Re: LT1 computer issue, no fuel
Fuel pump fuse?
Old Oct 25, 2013 | 10:02 AM
92rslt1's Avatar
Originally Posted by pizzi-man
Fuel pump fuse?
The fuel pump fuse provides power to the relay. If I jump the relay feed power to the pump wire it runs fine
Old Oct 25, 2013 | 02:37 PM
Does the relay operate if you apply 12v to it in lieu of the 12v signal from the PCM? Your last statement is not clear to me in that regard.
Old Oct 25, 2013 | 03:03 PM
92rslt1's Avatar
yes, if I apply 12v to the relay in place of the pcm wire, it will click and the car will start.
Old Oct 25, 2013 | 03:19 PM
I'd say you need to check the output of the PCM at the pin that provides the 12v signal and see what you have there. If you don't get the 2 second prime at key ON at that location, then the PCM is going to be suspect.
Old Oct 25, 2013 | 04:17 PM
It appears from your screen name you put an LT1 into a 92 RS. What year is the ECM/PCM? Did you install the complete PASS-key system?
Or is this actually a different vehicle? If so, please add details, as in the form of a
"Signature".
Gtpguy
Jan 26, 2015 04:50 PM
Jan 5, 2015 07:14 PM
cmdeshon
Jan 4, 2015 11:15 AM
Jul 4, 2005 05:00 PM
