LT1 clutch slave cylinder? replace? GM/aftermarket? how much $?
Old Jun 22, 2003 | 12:02 PM
93_Z28_6spd's Avatar
I am doing a clutch swap on my 93 Z 6 speed car. The slave cylinder has a thin like limiting cord on it maybe to keep it from moving too far on the clutch fork?
Anyways when I took it off the tranny, that little cord is broken. And the actual needle on the slave cylinder is flopping around.. I have not seen anything like that on previous cars I have worked on.
My question is I probably should replace it, but I went on gmpartsdirect.com and they want 129.00 for the slave master kit, that comes with the fluid reseviour as well ... I just want a slave cylinder but if i have to replace it all , oh well.
anyone have a clutch slave cylinder that is aftermarket? or everyone use stock gm parts?
Is there anyplace to pick up on a little cheaper then that? I can call my buddy on monday at the dealer and see what he can do, but I would pick your guys brains and see what you say. Thanks in advance!!!
Paul
HectorM52
Jul 30, 2017 11:46 AM
Jazsun
Dec 29, 2014 12:14 PM
siguy
Nov 27, 2014 10:07 AM
