LT1 - check your MAP sensor vacuum line
Old Nov 24, 2009 | 03:04 PM
stopthatman's Avatar
mine was making a hisss and little down on power, small vacuum tube to the MAP sensor was cracking around the end, it's the one under the PCV on passenger side.
wrapped some electrical tape and used a screw down band clamp. all fixed much better. should probably eventually buy a new one tho
Old Nov 24, 2009 | 04:28 PM
Sorry, but the MAP sensor has no tube. It is directy attached into the intake manifold.
http://shbox.com/1/map.jpg
Old Nov 24, 2009 | 04:44 PM
JAKEJR's Avatar
Under the PCV on the passenger side? Vettes are different, my PCV is on the driver's side. Describe what it was you fixed.
Jake
West Point ROCKS! Nation's TOP COLLEGE per Forbes Magazine!! Graduation Day Parade 20 May 2010!!!
Old Nov 24, 2009 | 05:35 PM
thanks shoebox, it's not the MAP, i found a photo from your excellent site
it's the tube under the PCV on the throttle body w/ the rubber elbow and plastic line. can someone tell me? thanks
Old Nov 24, 2009 | 06:01 PM
JAKEJR's Avatar
Okay, I see. I was thinking you were referring to the positive crankcase valve itself.
Jake
Old Nov 24, 2009 | 10:34 PM
First, the top hose is not the PCV tube. Its the hose that supplies clean, MAF measured air to the passenger valve cover so the PCV valve on the driver's side of the intake manifold can pull the air through the crankcase and the lifter valley.
The hose below that is the vacuum source for the EVAP purge system. The solenoid on the bracket on the passenger side of the intake manifold opens, to allow engine vacuum to pull air in through the charcoal canister, in the drivers rear fender, to purge the hydrocarbons it has collected from the vapor venting from the fuel tank.
Again, Shoebox has the answer:
http://shbox.com/1/evap_sol.jpg
http://shbox.com/1/evap_system.jpg
http://shbox.com/1/1995_evap.jpg
http://shbox.com/1/1996_evap.jpg
Old Nov 25, 2009 | 04:49 AM
Thank you Injuneer, it's the EVAP tube 10105324 it was hissing, awesome thanks!
oldschool
Feb 9, 2016 09:21 PM
teal98
15
Sep 16, 2002 01:23 PM
danielbmx
Aug 27, 2002 11:11 PM
johnsocal
21
Aug 17, 2002 01:06 AM
SilverWS6
13
Aug 14, 2002 09:29 PM
