LT1 Cat Delete Pipe
Old Apr 9, 2004 | 12:06 AM
Twice The Fun's Avatar
LT1 Cat Delete Pipe
is there such a thing, or would an 18" or so piece of 3" pipe work the same......also how do you mate the catback up to this pipe....is there and s pipe available somewhere.....exhaust shops wont touch my open y, no cat car....need any info possible.
Thanks.
Old Apr 9, 2004 | 02:06 AM
Prorac1's Avatar
I did this on my 94 z. I took the end of the cat that mates to the catback and cut it off. Than i welded it to a piece of 3 inch tubing, expanded the other end at an exhaust shop slipped it over my y pipe, bolted it up to my cat back, and viola........a test pipe. Hope this helps, Prorac1
Old Apr 9, 2004 | 02:11 AM
chesee48's Avatar
off road pipe u mean right?
Old Apr 12, 2004 | 08:41 PM
off road pipe...i guess.....more or less just something to go from end of y-pipe, which is very short, ends where cat would have started.......and run all the way back to catback...
thanks Prorac1
Old Apr 12, 2004 | 09:19 PM
Z28ROC's Avatar
You can buy one from mac and a couple of other manufacturers, Or you can make one. Here's a pic of one I made out of a bullet muffler. Sounds better than a straight pipe imo.
http://www.z28roc.cz28.com/Bullet.jpg
Old Apr 12, 2004 | 09:51 PM
nat's Avatar
nat
I don't know what kinda exhaust you're running, but you might as well just throw a cutout in there, it's not that much more expensive.
Old Apr 13, 2004 | 06:30 AM
Eliminator's Avatar
RKsport sells a 3 inch pipe for $99.
Old Apr 13, 2004 | 08:12 AM
PatriotTA's Avatar
You could buy a section of exhaust tubing at AutoZone or anything like that or even a muffler shop. Then flange both ends of that and flange the other end of the cat. Then you can quickly switch between hollow pipe and a cat.
alphaauto
Jan 23, 2015 07:42 AM
Jason Short
Jan 19, 2015 06:34 PM
Jan 5, 2015 07:14 PM
cmdeshon
Dec 27, 2014 10:06 AM
joffer00
Exhaust System
Dec 22, 2014 03:25 PM
