lt1 to carburator
Old Jul 27, 2003 | 03:08 AM
FLIPPINZ28's Avatar
lt1 to carburator
i want to make my lt1 into a carburated engine but use my lt1 block it is for a 93 z28 i am doing a stroking my block into a 414 ci lt1 but i want to go with carb instead of fuel injected is there a kit for this or is this in possible thanks alot for any info
Old Jul 27, 2003 | 04:49 AM
Keith5's Avatar
You can get carb intakes for the lt1. You could get the intake, a carb, and a distributor, figure out the may other meany details and be ready to go.
I don't know about fitting a distributor under that cowl/firewall though.
Old Jul 27, 2003 | 01:01 PM
FLIPPINZ28's Avatar
thanks anybody else know where i can get one and if i could do it
with my block
Old Jul 27, 2003 | 01:32 PM
FLIPPINZ28's Avatar
okay i found the intake and carb but how hard will it be to find the distrubuter and has anyone on here done this
Old Jul 27, 2003 | 02:52 PM
Keith5's Avatar
It's a chevy small block, there are a countless distributors for it! You need to make sure that you get one that will work with a roller cam. That is the only advice I can give you on that. I think roller cams are harder than the older style and require a harder distibutor gear.
If the distributor says it fits SBCs from 87 up, I would think it should work.
Old Jul 27, 2003 | 11:15 PM
FLIPPINZ28's Avatar
thanks also what about the opti how do i delete it
Old Jun 17, 2004 | 10:24 PM
hot_red_z28's Avatar
I've been considering the same thing. I've been told there is a part (#12367600) which is a plug for the timing cover where the opti drive it...
-Garrett
Old Jun 17, 2004 | 10:28 PM
Serene's Avatar
couple questions. why switch a factory FI car over to carb? its like a downgrade....
and why use the lt1 block? just get a sbc and put it in there.
Old Jun 17, 2004 | 10:37 PM
ninetythreez's Avatar
There is a GMPP adapter to make the opti run sparks. You will not get the throttle response from a carb that you will with MPFI. The GMPP also sells the carb intake but it has the hole in the rear for cam driven distributor. I guess you could plug the hole somehow or cover it up with a metal plate and bolt it in the distributor hold down clamp threaded hole. May I ask, why a carb? Get a bigger throttle body, injectors and pcmforless chip, etc..
Either will be appx $700-up.
Old Apr 5, 2006 | 11:22 PM
fattyz28's Avatar
Re: lt1 to carburator
If your z is a 93, don't get the opti cover. IT WILL NOT FIT! I wasted $60 to find that out. I am using MSD for my ignition. I don't have it all hooked up, but I was told I could take an ignition lead and run it to my box, which of course will tie in the the distributor and the coil. I got a new pro-billet distributor that MSD offers with a crap style cap to help clearance issues that I was afraid I might come across when I do the swap. I am not to that point yet of installing the ignition yet. I am disassembling mine at the moment. With working 2 jobs time isn't readily available. I hope to have it running in a couple more weeks.
I hope it will all be worth it!
DirtyDaveW
Mar 15, 2015 07:01 PM
Noer
Feb 28, 2015 11:29 AM
InfernalVortex
Jan 17, 2015 09:35 AM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
DirtyredT/A
Jul 29, 2002 11:27 PM
