lt1 carb (opti hole plate)
Old Jun 20, 2004 | 05:11 PM
lt1g3n's Avatar
anyone know where i can get the plate to plug the hole for the optispark ? im going carb and i was told i need this plate , can i just make one ? :/
thanks
Old Jun 20, 2004 | 05:14 PM
RamAir95TA's Avatar
Re: lt1 carb (opti hole plate)
thanks
It is part number 12367600, and availabe from http://www.gmpartsdirect.com . Hope this helps.
Old Jun 20, 2004 | 05:29 PM
lt1g3n's Avatar
nice thanks ! :P one quick question also :P, there is a coupler for the water pump, do you happen to know the part # for that too, every time i call a parts place they dont know what the heck im talking about, thanks , yes it does help !
Old Jun 20, 2004 | 06:04 PM
RamAir95TA's Avatar
If you are talking about the splined water pump drive shaft coupler that connects the water pump driveshaft and the water pump, it is part number 10128334 . Amazingly, GM charges $35.00 for it. I may have my old one that I removed for my Cloyes/CSI install if you want it.
Glad I could help you out!
Old Jun 20, 2004 | 08:01 PM
lt1g3n's Avatar
yes thats the one ! , watcha lookin to get for it ?
Old Jun 22, 2004 | 05:33 AM
RamAir95TA's Avatar
I'll be over at the shop later on today...let me see if I can find it before I do anything.
Old Jun 22, 2004 | 02:27 PM
lt1g3n's Avatar
ok sounds good, i was told there was only one intake that works for lt1 that supports a carb, is this the one, or is there more ?
Thanks, get back to me
Old Jun 22, 2004 | 02:32 PM
CamaroBoy96Z28's Avatar
You can use any intake. The GEN I SBC bolt pattern just has to be converted to the LT1 pattern and thats a simple job for any competent machinist.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
edman
Jan 22, 2015 02:45 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Queens94z28
Dec 20, 2014 09:11 PM
