lt1 camshaft gear
Old Nov 21, 2004 | 12:35 PM
wicked cmr's Avatar
lt1 camshaft gear
Anyone know if the camshaft gear on the lt1 cams are the same as the 305/350 first gen motors camshaft gear? cuz i put one that someone told me was from a gen I motor in my lt1 with my cc305 cam, and at high revs i here a little clickin , could it be the distributor grinding at the camshaft? mebbe they dont match or something.
Old Nov 21, 2004 | 12:39 PM
lillbush5555's Avatar
Re: lt1 camshaft gear
Are you talking about the gear on the back of the cam where the oil pump drive slids in? is so then YES they are the same but as far as the front of the cam it is different due to the opti. LT1's DONT have a distibuter on the back of the motor like a standard SBC..we have a POS OPTI in front. as far as clicking it might be your lifters. I would try cleaning out the motor with a bottle of seafoam.
Matt
Old Nov 21, 2004 | 12:45 PM
wicked cmr's Avatar
Yes thats what im talking about, hmmm... well when i pulled my magentic plug from the oil pan to change the oil i seen metal color i wasnt sure if it was shavings or what or just clumped up oil, i doubt it cuz its a brand new motor and the oil is clean so im pretty sure the gear is grinding , the kid i bought the distributor told me it was from a sbc from a camaro ,but i for some reason really doubt it, i think imma buy a new one just in case to be safe, what distributor can i buy from like summit that will work safely?
Old Nov 21, 2004 | 12:49 PM
there is only 1 dis that will work and it is called a OPTI. we dont have the kind in the back of the motor. summit sells them but I would reccomed getting 1 from a ealer. and the opti has nothing to do with shaving in the oil. you say it is a new motor you can expect SOME shaving in the oil due to everything breaking in. if there is aLOT of shavings there might be some problems. what type of car do you have? TA, Z28 and also what year?
Matt
Old Nov 21, 2004 | 12:51 PM
wicked cmr's Avatar
oh no, its very minor, barely any tbo... so its normal then, its a 83 z28 , i put an lt1 in it, but i went carbed instead of FI and so im using the rear mounted distrubutor instead.
Old Nov 21, 2004 | 12:56 PM
OK well I get it now. I would just call summit and tell them what you have and you need a dis for a LT1 but it has a carb and no OPTI so you will need a DIS for a SBC. Hope this helps if not hopefully someone else will chime in here and give you the help you need
Matt
Old Nov 21, 2004 | 01:32 PM
wicked cmr's Avatar
ok great ,thanks alot
HCz28
Jan 11, 2015 11:17 AM
1775.Z28
Jan 11, 2015 10:51 AM
ddr698
Jan 9, 2015 10:05 AM
Jul 4, 2005 05:00 PM
