LT1 Cam
Old Dec 29, 2007 | 09:50 AM
MrCamu's Avatar
LT1 Cam
Have anybody had this cam 07-502-8 in engine?
Is it good cam?
Old Dec 29, 2007 | 12:45 PM
joeSS97's Avatar
Is it good cam?
It is a great cam for a daily driven car.Nice lope,torque acroos the band,and excellent mileage.I am sure you would be happy with this choice.
Old Dec 29, 2007 | 12:53 PM
dangalla's Avatar
what are you looking to do with the car, what are your goals
Old Dec 31, 2007 | 10:22 AM
MrCamu's Avatar
well, I expect something 350+hp from the engine and good low rpm torque, is it possible?
Heads are ported stock LT1 heads, intake is matched to heads, 1.6 rockers, shorty headers+3" exhaust and something minor modifications(msd 6al, cold air intake, etc.)
I drive with it daily in summers.
Old Dec 31, 2007 | 10:40 AM
BUBBA's Avatar
I'd go with the Crane 104227. Good low-end torque with stock-like manners.JMHO
Old Jan 1, 2008 | 09:01 AM
MrCamu's Avatar
here is the 07-502-8 cam specs:
Basic Operating RPM Range: 1,500-5,500
Intake Duration at 050 inch Lift: 218
Exhaust Duration at 050 inch Lift: 224
Duration at 050 inch Lift: 218 int./224 exh.
Advertised Intake Duration: 269
Advertised Exhaust Duration: 276
Advertised Duration: 269 int./276 exh.
Intake Valve Lift with Factory Rocker Arm Ratio: 0.495 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio: 0.503 in.
Valve Lift with Factory Rocker Arm Ratio: 0.495 int./0.503 exh. lift
Lobe Separation (degrees): 112
and I have 1.6 rockers, so the valve lift is about .53"
Old Jan 2, 2008 | 03:48 AM
MrCamu's Avatar
well, is 350+hp possible with comp 502 cam and these mods?
Old Apr 26, 2009 | 04:22 PM
Dnsean's Avatar
well before my longtube, 52mm throttle body, slp lm2, ngk iridium plugs, i was at 280rwhp, 306rwtq.. on stock heads but springs 1.6rr and 218/224 cam... so mysetup now should be hopefully 300rwhp, 316-320rwtq... so with wht you have now... depending on specs of heads id think youd be closer to 350rwhp maybe? but shorties are still too restictive so swap over to longtube if you can.. if not true dual 2 1/2 piping will help over 2 1/2 restrictive ypipe (esp pacesetters)
rideordie
Nov 5, 2019 04:52 PM
oldschool
Feb 9, 2016 09:21 PM
InfernalVortex
Jan 17, 2015 09:35 AM
Queens94z28
Nov 20, 2014 06:03 PM
