Lt1 bored 383 and 383 stroker horsepower ?
I'm wondering if anyone would know by a guess of what the horsepower would be on a bored out lt1 350 to a 383 with all stock components besides the pistons and what a 383 stroker would be with all stock components besides the rotating assembly would be.
Re: Lt1 bored 383 and 383 stroker horsepower ?
Whaaaa? You can't bore a 350 to a 383. And you can't achieve 383 cubic inches without boring the block .030 over WITH a 383 rotating assembly as far as I know
Displacement isn't as important as what's on top of the motor (for 98% of us). The biggest, baddest engine in the world isn't going to be very impressive if the heads and cam aren't up to snuff. On the flip side if you throw a great (great does not mean huge or expensive) heads/cam setup on even a modest sized engine it will still run pretty well.
A 383 can make the same HP with a cam that will probably be a bit more street friendly than the cam required to make that HP level with a 350.
As mentioned.....going from a 350ci to a bored AND stroked 383 will only net you a handful of HP if the heads and cam are stock.
Also, as mentioned, horse-power is made more-so with the heads and cam than with displacement; and more compression is a VERY important element when going with a bigger (more agressive) cam.
NOTE: more stroke and higher compression should increase torque pretty significantly
350ci = 3.48" stroke and 4.000" bore.
383ci = 3.75" stroke and 4.030" bore.
To go with a 383ci, at the very least, you'll need 4.030" pistons and a 3.75" crank. You could keep the stock rods (I wouldn't) if your pistons are spec'ed for 5.7" rods. But I'd get pistons spec'ed for the 6" rods that I'd be using
KW
.350ci = 3.48" stroke and 4.000" bore.
.KW
F'n1996Z28SS
Aug 23, 2023 11:19 PM
