LT1 bolt on questions
i have a A4 z28 with 100k miles, the bolt on mods are
1. k&n intake
2. smooth elbow
3. descreen maf
4. 160* thermo
5. throttle body air foil thing
6. no cat
7. magnaflow catback
8. tb coolent bypass
what is the next mod i can do that makes the most sense?
i was thinking of a pcm4less mail order tune... it it nessessary at this point???
1. k&n intake
2. smooth elbow
3. descreen maf
4. 160* thermo
6. no cat
1. k&n intake
2. smooth elbow
3. descreen maf
4. 160* thermo
6. no cat
1. k&n intake
2. smooth elbow
3. descreen maf
4. 160* thermo
6. no cat
Headers, Gears, RR's, PCM Tune
Gears gears gears. 3.73s. and a shift kit at the same time. make your tranny last longer. i think you have the junk 2.73s now (not sure tho) and if so that's the single best thing you could ever do to the A4. mileage will come down a bit highway. will need to reprogram for speedo change so get a tune while you're at it. very simple to do yourself though if you just change for tune, will cost you $65 for cable and $20 for tuner file and 30 day free trial of Tunercat. with some research and trial and error you can change your shift points, speedo, and a very basic performance tune (adjust timing curve at least safely).
I'm basically in the same boat
I'm thinking:
1) Headers and Y-pipe (probably Pacesetter... maybe coated?)
2) Tune (maybe buy a cable and s/w??)
3) 1.6 RRs
4) Tune again
5) SFCs
6) Underdrive pulleys
7) 3:xx gears and shift kit
8) N2O (maybe... JUST for when you're next to a rustang... otherwise waste of space, $, etc for me)
It is all about the $... boss lady was just busting my 'nads saying "you spend too much on that car"... Well... her POS Kia Sorento needs new plugs (basically 60K service... at 77K
... which is gonna cost $500 or more... NO room to work on that POS, and I can't be bothered.
I figure it is cheaper to slowly mod a car and maintain it that a new car payment... at least that way you know what you're dealing w/.
3) 1.6 RRs
4) Tune again
5) SFCs
... which is gonna cost $500 or more... NO room to work on that POS, and I can't be bothered.I figure it is cheaper to slowly mod a car and maintain it that a new car payment... at least that way you know what you're dealing w/.
Jul 4, 2005 05:00 PM
