lt1 block (stroke)
Old Jun 15, 2005 | 01:59 PM
EVERESTZ28's Avatar
lt1 block (stroke)
what exactly machine work needs a lt1 block to install a 383 or 396 kit?
Old Jun 15, 2005 | 02:07 PM
FireFox05's Avatar
Re: lt1 block (stroke)
As far as I know, none. You only replace existing parts, that is, crank, rods and pistons.... I'm sure someone else will tell me I'm wrong, but that's my $0.02.
Old Jun 15, 2005 | 02:12 PM
EVERESTZ28's Avatar
so, no clearance for rods or something? just bore to new piston?
Old Jun 15, 2005 | 02:22 PM
GetaZforgetGT's Avatar
For a 383 you will at a minimum need to have the cylinder bore.
In most cases the block will need to be machined down by the pan rail so the rod bolts will clear. Some didn't have to clear for that but others have.
Forr a 396 the same will need to be done and in most cases there will need to be clearance in the cam area for the rods. A lot of people run a small base circle cam with 396 setups.
If you do a search on this you should get a mountain of information.
Actually there is a lot of things that should be done to make it last so I definately do a search.
Old Jun 15, 2005 | 03:22 PM
EVERESTZ28's Avatar
anyone have a specific link? i'm doing a search but i haven't found it yet!
Old Jun 15, 2005 | 03:28 PM
z96's Avatar
z96
Call Chad At Golenengineservice.com Their Building My 383. Thie Is One Guy Who Will Build You Engine And Answer All Questions And Not Blow You Off The Phone
willismoons
Feb 14, 2015 08:42 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
95z_28_camaro_4_Ivan
Dec 19, 2014 08:48 PM
squinn
Aug 4, 2002 01:06 PM
