LT1 block filled hotter or not
Old Sep 29, 2007 | 02:41 AM
sleeperz28's Avatar
Like the title says. I still drive the car on the street. Right now my temp stays right around 190 crusing. Im curious to see what temp differences people notices after they 1/4 filled their block.
Old Sep 29, 2007 | 08:18 AM
rskrause's Avatar
Moderator
It will make no difference in water temp. The oil will be hotter, which is a good thing to a point. And unless you go for LOOONG periods of WOT will not be a problem.
Rich
Old Sep 29, 2007 | 01:20 PM
sleeperz28's Avatar
With turbo cars one problem we do have is oil temps. Just crusing around on a warm day mine get to about 210 which is not that big of a deal. But do you know how much hotter they might get?
Rich you say 1/2 fill the block. Is that just below the freeze plugs? Also why do you say 1/2 fill?
Old Sep 29, 2007 | 02:46 PM
lt4_transam's Avatar
ive got a 383 lt4 trans am that has the block filled to just below the freeze plugs to get ready for twin turbos and my car never gets much above 180. i run distilled water and use 2 bottles of water wetter with a 160 thermostatand have no probs at all with temp.
Old Sep 29, 2007 | 07:13 PM
sleeperz28's Avatar
anyone log oil temps before and after?
What is the process for filling a block. Do you just have to remove one freeze plug or do they all need to come out?
thanks for the replys
Old Sep 29, 2007 | 07:15 PM
razor02097's Avatar
my aircooled bike reaches 270 sometimes if that helps?
horray my 500th post
Old Sep 29, 2007 | 07:24 PM
93Phoenix's Avatar
pics/vids of car plz
Old Sep 29, 2007 | 08:22 PM
my block was filled while i had the motor out to be bored and stroked. the machine shop i took it too cut the block too much for rod bolt clearance so they had to fill it. i believe they took out all the freeze plugs and filled it. after they fill it i ran some ceramaseal through it to coat the filler so antifreeze wouldnt bother it if i ever decided too.
Old Sep 29, 2007 | 09:54 PM
rskrause's Avatar
Moderator
It is poured in through the coolant passages in the deck surface.
Rich
F'n1996Z28SS
Aug 23, 2023 11:19 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
Sandersen511
Jan 13, 2015 03:49 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
