LT1 58mm throttle body?
Old Dec 30, 2003 | 09:27 PM
88RX7LT1's Avatar
I will have ported and polished heads with larger valves and cc305 cam. Any reason to go to a larger tb?
Old Dec 31, 2003 | 07:06 AM
QUASARBLUEZ28's Avatar
Stock intake? Run a 52MM. 58MM would be a waste without a proper intake for it.
http://community.webshots.com/album/33786390mmhudJ?888
Old Dec 31, 2003 | 07:47 AM
SMOKINV8's Avatar
You need a larger throttle body than the stock 48mm with that combo. If you run a 58mm with a 4L60e transmission, you'll need to do a little tweaking on the line pressure. Also, with the 58mm you'll need to port match the intake to the throttle body. If you go with the 52mm, you won't have either problem. And if you have an M6, you won't have the line pressure issue either.
I'm also not sure what's considered a "proper intake" for a 58mm TB, but maybe somebody cound find some cfm flow numbers for both, and compare them. Or have you already done this quasar?
Old Dec 31, 2003 | 08:20 AM
By "proper" it was meaning that the stock port is too small / restrictive for a 58MM T.B. A 52MM however is OK. Sorry, don't have the CFM flows between the various T.B.'s, however I do recall seeing them someplace online. I'll post the site if I run into it again.
Old Dec 31, 2003 | 09:09 AM
Antz97ZNJ's Avatar
Id dont think theres any reason to change unless your running some type of forced induct. or a big stroker motor
Old Dec 31, 2003 | 08:50 PM
wes95_z28's Avatar
Interesting... right after i installed my throttle body i bought off of a friend i noticed my transmission was shifting weird then couiple days later my tranmission went out again i just thought it was a dumb luck.
What do you mean by tweak the line pressure and how do you do it
Old Dec 31, 2003 | 08:56 PM
Josh-'04 GTO's Avatar
The "standard" flow numbers tossed around for throttle bodies is:
48mm= ~660cfm
52mm= ~750cfm
58mm= ~1000cfm
monoblade= ~1300cfm
I'm sure there might be a little difference between brands, but that's close enough.
Old Jan 1, 2004 | 03:52 PM
QCKZ28's Avatar
all you have to do to make your intake "proper" for a 58mm TB is, port the opening of the intake to match the 58mm TB gasket.
a dremel tool would do the trick.
jesse
Old Jan 6, 2004 | 09:46 PM
88RX7LT1's Avatar
I think this maybe?
http://users3.ev1.net/~thor10/HP-FAQ.htm
Old Jan 6, 2004 | 09:52 PM
QCKZ28's Avatar
Re: I think this maybe?
we have a local board member here that is or was porting stock TB to 52mm...
do a search for NOMAD
jesse
Old Jan 7, 2004 | 04:19 PM
It only costs me $75 to have my local machine shop bore my stocker to 52mm and make new plates to fit. My brother paid a little more ($90) from a different machine shop to do the same thing, so paying $150 or more to overbore a stock throttle body sounds a little high.
HectorM52
Jul 30, 2017 11:46 AM
oldschool
Feb 9, 2016 09:21 PM
lt1-xjs
Jan 17, 2015 07:52 PM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
