Can this happen to us?? see inside
Old Jan 7, 2004 | 06:12 AM
MentalCaseOne's Avatar
While surfing around I came across this website:
http://autorepair.about.com/cs/generalinfo/l/bl827d.htm
It mentions a TSB on Contaminated MAF sensors. I wondered has this ever happen to the LT1's?
Old Jan 7, 2004 | 06:26 AM
InjectedSS's Avatar
Why are you comparing Fords TSB's to our cars?
Yea MAF's can go bad ON ANY CAR, but comparing a Ford TSB to our car is completly irrelivant That's like posting up asking if a tire can blow out on our car's because you saw TSB about some firestone tire's that were falling apart
Old Jan 7, 2004 | 07:12 AM
so are you saying that GM Camaro MAF technology is soo far behind FORDs MAF technology that theres no way this can happen to us? I mean GM doesn even make the Camaro anymore.
Here it goes again... has any Camaro MAF been diagnosed with contamination? I didnt know MAFs could get contaminated so this info its new to me.
Marvin
Old Jan 7, 2004 | 07:36 AM
Onyx LT1's Avatar
I've never seen anything about someone's MAF being contaminated. But like it was said above, that's like comparing apples to oranges. I'm sure if you search enough, you can find out if any TSB's have come around involving that.
Old Jan 7, 2004 | 07:43 AM
RacinLT1's Avatar
sure it's possible,but i havent heard of it, and if someone has had the problem,it probably wasnt labeled as "contamination".
2 different design's of MAF sensors anyway,the gm is more efficient at self cleaning. remember,GM has been at the maf setup longer then ford,so doesnt matter if the fbody is made anymore or not.
Old Jan 7, 2004 | 09:30 AM
neat's Avatar
The MAF sensors are completely different. Ford uses a sampling tube, while GM stretches a wire accross the entire diameter of the MAF.
Old Jan 7, 2004 | 11:26 AM
93Z286Speed's Avatar
Marvin
how is mouthing off relevant to the question
They are right they are 2 different systems, weather the fbody is still in porduction or not is not relevant at all.
TSB's are usually very specific, meaning If its for a 95 exploder or whatever, it usually ONLY applys to that 94 exploder with a 4.0 or 5.0 whatever it was.
Old Jan 7, 2004 | 04:21 PM
InjectedSS's Avatar
Marvin
WTF?? Dude what does GM not making f-bodys anymore have anything to do with MAF's? I think it sounds like you need to go buy a ford
WERD, that's what Im talking about
HibachiZ28
Nov 6, 2015 12:53 AM
karpetcm
Sep 15, 2015 11:07 AM
Cbr02
Aug 24, 2015 07:12 AM
Schul365
Aug 22, 2015 10:00 AM
Aug 17, 2015 09:50 AM
