LT1/4 Starter Differances?
Old Aug 12, 2003 | 08:28 PM
Izod's Avatar
Are there any? I heard the LT4 starter is slightly longer and makes for more of a pain with LTs. I do know that the LT4 starter doesn't have a core charge though. Thoughts?
Old Aug 12, 2003 | 08:38 PM
The LT4 starter is smaller. Look here from Wilson's page.
Old Aug 12, 2003 | 08:41 PM
Izod's Avatar
ah ever our saviour shoebox! THANK YOU!
Old Aug 12, 2003 | 08:58 PM
If I don't have a pic, someone else usually does.
Old Aug 23, 2003 | 08:28 AM
Lounge Lizard 6's Avatar
How does one convert the 3 post LT1 to the 2 post LT4? Seems the small wire is missing a place to go on the LT4 starter.
Old Aug 23, 2003 | 08:43 AM
There are only two wires that go on the starter-the battery cable and the purple wire from the switch. No real conversion needed.
Old Aug 23, 2003 | 09:35 AM
I've got a small gauge wire that runs to the small third post. It uses a 5/16 nut. On the link provided above you can see it best in the top middle or right hand shot.
Old Aug 23, 2003 | 09:41 AM
thewinner's Avatar
the lt4 already has the wire built into it.
Old Aug 23, 2003 | 10:23 AM
Hyperspeed97z28's Avatar
LT4 Part # ??
Old Aug 23, 2003 | 10:27 AM
Mtrhds94Z's Avatar
10455709
Old Aug 23, 2003 | 10:30 AM
What do I do with the dangling wire? Shouldn't it connect to something?
Old Aug 23, 2003 | 10:47 AM
thewinner's Avatar
stop worrying about it. you only have 2 wires coming from the wiring harness to the starter. that little wire is self contained on the lt1 starter.
Old Aug 23, 2003 | 12:13 PM
Dan Parker '96's Avatar
It's not an LT4 specific starter. It's more likely a year change. My '96 LT1 (in a Vette) has the same starter as an LT4.
Old Aug 23, 2003 | 03:51 PM
Where does this wire come from and what color is it? What year is your car?
Old Aug 23, 2003 | 05:54 PM
pennys58's Avatar
I see that the starter costs $144, can be found cheaper, or has anyone gotten it from Jason or Dal cheaper?
JOHN
