lt1 383 stroker help
i want to make my lt1 into a 383 stroker that will push 500hp+ i been doing alot of research on this i can seem to make up my mind on what parts to use... can anyone put a list of parts i should use or recommend?
Re: lt1 383 stroker help
500flywheel or rear wheel?
How modded is the car already? Car needs a LOT of work first.
Also you should understand that heads and cam can get you 500fwhp on a good condition stock shortblock and that displacement helps a LOT less than most assume it does.
Checking out signatures to see combos can be useful if there are RESULTS listed and you can consider "result for effort".
If you compare two cars and one is .2 faster but has an extra $2K in aftermarket heads, more displacement and a trailer queen would you rather listen to the guy who is technically faster or the guy who got damned near the same result in a driver that cost a lot less to build?
You really need to put in a lot of time to figure out who to trust before you go spending money based on advise from a forum.
As far as the tranny goes, my stock one was slipping at high rpm/boost, but definitely did not grenade it.
Regardless it is foolish to assume a stock drivetrain can handle a 500HP engine.
Put a set of slicks on it and make a track pass and let me know what happens. Hope you have AAA.
