lt1 383?
Old Mar 14, 2010 | 10:39 PM
Crafty's Avatar
lt1 383?
I have a stock LT1 engine from a '93 camaro z28, but it needs a rebuild (Broken connection rods, or so i'm told; haven't had a chance to tear it down yet). So I was wondering if it would be better to rebuild it stock or make it a 383. From what I heard its to make it a 383 I would just have to buy new rods and crank out of a 400 small block and to bore my block 30 over.
Old Mar 14, 2010 | 11:09 PM
old93camaro's Avatar
lol yea if your building a Gen 1 motor with a Gen 2 lt1 you just need a 3.75 crank and 30 over.
Before you can determine what to do, you have to assess the damage. A broken connecting rod ("rods"???) can do major damage, rendering the block unusable.
You wouldn't use the crank and rods out of an SBC 400. You buy a one-piece rear main seal crank with a 3.75" stroke, and a set of rods - either 5.75", 5.85" or 6.00" (but not the 400's 5.565") - and a set of 4.030" pistons with the correct compression height to go with your rod length and the block's deck height, usually a bit over 9.00".
D1SC383LT4
Jan 1, 2016 01:56 PM
cheapchevy
Apr 8, 2015 08:48 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
