Lt1 350 to 383 stroker
Old Mar 16, 2013 | 10:37 PM
SSdatboiuda's Avatar
Way is the best 383 stroker kit? And I have a shop here in the bay Florida speed and performance that will do a 383 stroker to my 96 z28 with my current 350 for around 4-5k...help wat is everyone's opions.??
Old Mar 16, 2013 | 10:44 PM
KW Baraka's Avatar
Re: Lt1 350 to 383 stroker
Originally Posted by SSdatboiuda
.......And I have a shop here in the bay Florida speed and performance that will do a 383 stroker to my 96 z28 with my current 350 for around 4-5k...help wat is everyone's opions.??
I know where a fully forged 383 can be had for less ----->> https://www.camaroz28.com/forums/par...-block-870670/
That's my story and I'm stickin' to it !
KW
Old Mar 16, 2013 | 10:58 PM
97WS6SCharged's Avatar
Are you looking for quality or price?
Old Mar 16, 2013 | 11:31 PM
Quality, and reliability yes and a good deal
Old Mar 17, 2013 | 09:15 PM
I've run Eagle's stuff before and wouldn't be afraid to run their forged stuff in a somewhat budget friendly engine. A 4340 crank with a good set of H beam rods should work fine once it's balanced without too much pain in the wallet.
Old Mar 21, 2013 | 07:31 PM
RamAir95TA's Avatar
For $5g you'll end up with a quality short-block and not much more.
What are your plans for this motor? Hopefully that budget isn't for the entire long block.
Old Apr 1, 2013 | 02:31 AM
AdsoYo's Avatar
I've been pretty happy with my Golen 383. I bought the 400hp long block for $5,500 4 years ago and after 25K miles it's doing great. It's got some cam surge and I usually add 1/4 - 1/2 a quart of oil between changes. I'm making 350 rwhp and 370 rwtq. Oh, and 23 mpg highway!
Old Apr 1, 2013 | 02:01 PM
redline9570's Avatar
Eagle has a forged kit for $900 machine shop work is $450 for the block and for another $400 they will put it together. I would say under 2k for a short block if you shop around, I did and that's what I came up with. If you don't have a 4 bolt block then you will have to spend extra for new caps and having the block tapped. 4k is way over priced for a short block sometimes when shops are busy they will give high estimates.
Old Apr 1, 2013 | 05:31 PM
tx20d's Avatar
PM sent.
Old Apr 2, 2013 | 08:50 PM
IrocSS85's Avatar
nah $450 is not enough. more like $1k
bore block
deck plate hone
align hone mains
clearance for stroker
deck the block (will depend on if you use -16cc dished pistons, or true flat tops)
hot tank block
optional machine shop:
custom cut piston rings to size
assemble rods to pistons
install cam bearings
install freeze plugs
Old Apr 3, 2013 | 09:39 AM
Skedaddle's Avatar
You won't need a 4-bolt main conversion for a normally aspirated 383 build. Forced induction/nitours - yes.
What are your goals for HP? You don't need a 383 to make 500HP for example.
Old Apr 3, 2013 | 11:45 AM
97 6SPEED Z's Avatar
Question Re: Lt1 350 to 383 stroker
Where ........ can you get any forged "kit" for just ..... $900 ???
Old Apr 6, 2013 | 08:23 PM
Seen it on craigslist when I was listening to all the forum jive about 383s and how great they are.... aside that just look on the parts for sale forums here you can get them sooooo cheap used. Resurface them would be a fraction of the cost to new.
D1SC383LT4
Jan 1, 2016 01:56 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
Killer94z
Jan 13, 2015 12:06 PM
spearous
Jan 12, 2015 11:03 AM
