Is and LT1 a 327 Block?
Old Feb 3, 2007 | 03:31 PM
2tight's Avatar
On the front right side of the engine block it has G-4 327 stamped on it, what does this tell you .
Old Feb 3, 2007 | 04:00 PM
94/96ZsM6s's Avatar
its a casting number, i think all lt1 350ci blocks have that cast on the drivers side.
Old Feb 3, 2007 | 05:31 PM
ayers1967's Avatar
The 327 on the block tells you its a 350 ci lt1 and not a 265 ci like what would be in a caprice, or a kingswood wagon.
Old Feb 3, 2007 | 05:52 PM
BlackScreaminMachine's Avatar
Same as above.
Old Feb 3, 2007 | 06:24 PM
ricehammer's Avatar
A 327 is a destroked 350 from the oldschool era, mid to late 60's. 3.25" stroke for the 327 vs 3.48" for the 350. Bores and blocks are the same.
Old Feb 3, 2007 | 06:35 PM
Craddock's Avatar
327's are in some newer vehicles too. I think my buddy's dad has a truck with a 327.
Old Feb 3, 2007 | 06:59 PM
elisowski's Avatar
The 350 LT1 and LT4 (4 bolt mains) have the casting number 10125327. The 327 on the block is the last 3 digits of the casting number.
The 265 block has the casting number 10168588. The is a "4.3" casting mark on that block. Go figure.
Old Feb 3, 2007 | 09:14 PM
327 is cast on all 4 sides of the block. ...the last 3 digits of the original block part number.
Old Feb 3, 2007 | 11:54 PM
exgmguy's Avatar
There has not been a "327" made in a long time.
Old Feb 4, 2007 | 12:19 AM
reamo04's Avatar
hate to tell ya, but theres 327s in newer silverados...
Old Feb 4, 2007 | 06:24 AM
Steve0's Avatar
The 5.3s are actualy 325c.i.
Old Feb 4, 2007 | 07:38 AM
rskrause's Avatar
Moderator
No, not really. The 327 preceeded the 350, so it would be more correct to say that the 350 is a stroked 327. Also, the 350's use different bearing sizes The main journal diameter was increased to 2.45" from 2.30" and the rod journal diameter was increased to 2.10" from 2.00". The 327 is thus called a "small journal" and the 350 a "large journal" engine.
Rich
Old Feb 4, 2007 | 08:14 AM
2tight's Avatar
So would this mean my has 4 bolt mains?
Old Feb 4, 2007 | 08:21 AM
rskrause's Avatar
Moderator
No, the block casting numbers are the same regardless of whether 2 or 4 bolt mains were installed. The part number differs, but that does not appear on the block. All blocks installed in F-bodies except the rare LT4 F-bodies (100 produced) has 2-bolt mains. The Corvettes got the 4-bolts as did some (?all) of the replacement engines.
Rich
Old Feb 4, 2007 | 10:53 AM
exgmguy's Avatar
And there are Hemi's in Dodge Rams.
