LT1... 1LE or Aluminum intake elbow?
Old Feb 13, 2008 | 01:42 AM
jasonface's Avatar
Any opinions on what's "better"? The aluminum elbows are smoother internally and should promote better airflow, but they're metal, would heat retention be a concern? Do the 1LE elbows really outflow the stockers?
Old Feb 13, 2008 | 02:17 AM
mad95z's Avatar
Let the flood begain........
Old Feb 13, 2008 | 03:22 AM
jasonface's Avatar
yeah, yeah, I should've checked through the search function first....seems to be about 8 PAGES of this same/nearly the same question. Humble apologies to all
Old Feb 13, 2008 | 05:15 AM
And you have not seen all the opinions by now?
Honestly, I don't see any of them being much different in flow. The 1LE is more convenient, because it does not have the silencer. It also has a bit thicker rubber on the TB end to make it more tear resistant than the stocker (a good thing, since that is usually where they fail).
Old Feb 13, 2008 | 06:41 AM
2000GTP's Avatar
There are no real performance gains to be had by an aftermarket elbow, might as well get what looks best to you cosmetically or what suits your application best.
Old Feb 13, 2008 | 02:52 PM
ABA383's Avatar
Beware that if you use or have a 58mm TB that most of the aluminum/metal elbows are actually smaller than the openings...Imho the 1LE is the better choice all around...But I like the look of being factory...When you open my hood you'd have no idea what lurks within... Hell, I still have A.I.R. and EGR...stock valve covers, A/C, P/S, etc, etc...
--Alan
Old Feb 13, 2008 | 03:34 PM
speed_demon24's Avatar
Judge for yourself.
Old Feb 13, 2008 | 08:33 PM
jasonface's Avatar
Originally Posted by speed_demon24
Judge for yourself.
WOW!! Good point, 1LE here I come.
Old Feb 13, 2008 | 09:38 PM
BigBadBlack93Z's Avatar
I seriously can't believe the prices that the 1LE's are going for. They used to be $45 all day long from Dal.
Old Feb 13, 2008 | 10:34 PM
As the cars get older, the prices for parts are increasing. A lot of parts are already being discontinued. Not much you can do about it.
Seems not that long ago a vented opti was $100 cheaper than it is today.
Old Feb 13, 2008 | 10:52 PM
no kidding. I couldn't believe how much standard replacement parts are that I have thrown away by the 10's a few years back.
Old Feb 14, 2008 | 01:47 AM
porksoda's Avatar
Dammit! I really wanted a polished elbow too just for the look but with those pics I don't know how much it cut down air flow.
Old Feb 14, 2008 | 09:53 AM
BTC's Avatar
BTC
From: Lansing, MI via Bowling Green, KY: Dalton, GA: Nashville, TN & Atlanta, GA
I went with a 1LE to replace my torn stocker. I really don't like the appearance of the aluminum elbows, but then again I've never been into curb feelers either.
How much are the 1LE elbows now? I think I paid around 56 bucks a year or so ago.
Does GM ever give advance notice of parts they are planning to discontinue?
Old Feb 14, 2008 | 07:39 PM
solarofthesix
Guest
Posts: n/a
i will have to get some pics but i got one from CRT and it doesnt look so small and the part on the TB was jsut about the same size as the TB Opening...ill have to check this again
Old Feb 14, 2008 | 08:04 PM
IROCThisZ28ForLife's Avatar
hey shoebox, that guy in your site, can he still get the non-vented optis for cheap?
and i was going to get a metal intake elbow, but decided to go 1LE, then decided to go turbo!! lol
