LT trim ban1=0.6 Bank2= 6.4 @idel
Old Mar 19, 2004 | 06:15 PM
93transam1234's Avatar
i a-taped my car while just sitting at idel and i noticed this.
What does it mean? what might cause it and what else should i look at?
And what side is bank 1 and bank2?
Old Mar 20, 2004 | 11:17 AM
EviLBoX's Avatar
1 = driver side
2 = passenger side
As far as those numbers go, they basically mean your car is "adding" a little fuel @ idle to adjust for a lean condition. You can't really tell much from just idle, drive the car around and get some more readings from different cells and post back.
Old Mar 21, 2004 | 01:38 PM
i drove around and look at several cells and in just about all of them the LTTrime for bank 2 is at least 4-12% higher than bank one (witch is around 3-7%)
What should i look at i know my O2 bank 1 sensor threw a code would that efect the LTTrim for bank 2?
Old Mar 22, 2004 | 01:45 PM
Does anyone know if this is even nornal or not?
I reset my PCM to try and see if it will re-learn these same LTTrim counts,
I dont know what to check for besides exhauset leaks which i dont have on bank 2 just bank 1
Old Mar 22, 2004 | 02:53 PM
EviLBoX's Avatar
I pulled this from the scanmaster page:
"If LBL for a Cell is a lot different than RBL for that Cell, there is something affecting one side of the engine. Example would be a leaky or clogged injector, an exhaust leak or a misfire. This is somewhat subjective, but I would suggest you look for reasons when the difference from right to left is 5 or greater."
http://members.aol.com/InjuneerZZ/ScanMast.htm
93 RedBird
Nov 15, 2015 08:24 AM
Hal Fisher
Sep 30, 2015 09:03 PM
drt
Sep 27, 2015 04:39 PM
cmsmith
Sep 14, 2015 09:25 PM
tdigger9899
Sep 7, 2015 10:56 AM
