LT and ST fuel trim reads high in data log
Old Aug 31, 2020 | 11:41 AM
  #46
Re: LT and ST fuel trim reads high in data log
Huge file, and probably not worth putting a lot of time into. Based on a quick run through:
- there are 8 cells where the LTFT's are at, or approaching 160. This should be obvious from a quick glance. It's not getting enough fuel.
- there are 6 cells (4, 10, 12, 13, 14, 15) you never drove in, in spite of the huge file (637,000 pieces of data). Again, based on a quick glance, you never got the engine over 2,777 RPM. You need to get some aggressive driving in to cover all the cells. It never went into power enrichment mode, where a fuel problem will show up even worse.
- there are rows and occasional individual spreadsheet cells of totally corrupt data Excessive interference on the data line????
- there are random DTC codes popping up and disappearing. Interference on data line ????
You have to sort out the fueling problem.
Cliffburton99
Jan 3, 2010 06:23 PM
Geardrive63
Aug 31, 2006 06:38 PM
Siamanis
14
Mar 28, 2006 12:46 PM
scoobysnax83
Apr 25, 2004 10:37 AM
teke184
Feb 18, 2004 09:35 AM
