LT parts list... again.
Old Aug 6, 2003 | 11:18 AM
Izod's Avatar
Ok,
I'm gonna need
The Felpros, ARP bolts, and 02 extenders and/or simms? Correct? Which part#s / sizes? Is felpro 1460 or 1470? Anything else? Not including tools, etc?
I apologize, I used the search function...
Old Aug 6, 2003 | 11:48 AM
anasazi's Avatar
no need for sims
don't forget zip ties and heat tape
Old Aug 6, 2003 | 11:52 AM
Izod's Avatar
any part numbers, etc for each of these?
CamaroBoy96Z28's Avatar
Fel-Pro is 1406. I second the zip-ties and heat tape, then a heat shield for the starter. Its not necessary but not a bad idea.
Old Aug 6, 2003 | 11:55 AM
JWA95TA's Avatar
Dont forget bolts to bolt the header to the y pipie. I know the jet hots and hooker y combo I got didnt have bolts. Had to go back to town and got lucky and found bolts at wal mart.
I think they need to be about 2 inches long?? or inch and a half. 3/8 I believe?? I forgot what size exactly.
I didnt use any heat tape, but I Know I need to get some.
Jason
Old Aug 6, 2003 | 12:01 PM
anasazi's Avatar
oh yea, some PBlaster or other type of name brand liquid wrench... not the autozone or discount auto brand.
Old Aug 6, 2003 | 12:21 PM
Izod's Avatar
yeah pblaster works miracles. =) 1406 why did i think 1460, who knows. which size ARPs is best? 3/8 or 7/16? the 4 flat 02 extenders right? - i need new 02s around anyways...
Old Aug 6, 2003 | 12:24 PM
speed76demon's Avatar
while you're changing your headers might as well get taylor ovc wires my stock ones burnt up pretty bad with my headers and change the plugs to ngk tr55
Old Aug 6, 2003 | 12:26 PM
Izod's Avatar
i just changed my plugs and wires, to the ngk55s, etc.
Old Aug 7, 2003 | 05:54 PM
SlickBlack Z's Avatar
The Stage8 bolts come in handy since they have allen key capability as well. Worth the investment!
Old Aug 7, 2003 | 06:07 PM
Black_Z28's Avatar
Yep, get the flat O2 extenders. You'll probably need 12"-24" extenders.
Old Aug 7, 2003 | 10:55 PM
Izod's Avatar
ok heres what i got
the felpros
the arps
the flat 4 02 extenders in 24" just in case.
heat sheild for my starter
and some heat shielding for other areas just in case.
Can anyone think of anything else? I'll probably be replacing the 02s while i'm in there.
Old Aug 8, 2003 | 08:24 AM
BitCypher's Avatar
Get yourself a set of mechanics gloves if you don't have them already. You'll be thankful if you wear them during the installation. Also, don't forget goggles. Lot's of dirt and crap will fall on your face while your under the car.
Depending on what LTs you purchased you may be able to stick with 3/4" bolts or you might go with 1" just to be safe. I ordered Jet-Hot LTs for my car and the 3/4" bolts were only about 5 threads past the header flange; to short IMO, so I'm using 1" bolts for the install.
Oh yea, make sure no kids are within hearing distance when you install them. They might learn a whole new vocabulary otherwise...
novaiiman
May 15, 2016 11:36 AM
Alex Barnes
Jan 24, 2015 10:21 PM
BIGCOWL-IMP
Dec 19, 2014 06:59 AM
