LT parts list... again.
Ok,
I'm gonna need
The Felpros, ARP bolts, and 02 extenders and/or simms? Correct? Which part#s / sizes? Is felpro 1460 or 1470? Anything else? Not including tools, etc?
I apologize, I used the search function...
I'm gonna need
Dont forget bolts to bolt the header to the y pipie. I know the jet hots and hooker y combo I got didnt have bolts. Had to go back to town and got lucky and found bolts at wal mart.
I think they need to be about 2 inches long?? or inch and a half. 3/8 I believe?? I forgot what size exactly.
I didnt use any heat tape, but I Know I need to get some.
Jason
Jason
ok heres what i got
the felpros
the arps
the flat 4 02 extenders in 24" just in case.
heat sheild for my starter
and some heat shielding for other areas just in case.
Can anyone think of anything else? I'll probably be replacing the 02s while i'm in there.
the felpros
the arps
Get yourself a set of mechanics gloves if you don't have them already. You'll be thankful if you wear them during the installation. Also, don't forget goggles. Lot's of dirt and crap will fall on your face while your under the car.
Depending on what LTs you purchased you may be able to stick with 3/4" bolts or you might go with 1" just to be safe. I ordered Jet-Hot LTs for my car and the 3/4" bolts were only about 5 threads past the header flange; to short IMO, so I'm using 1" bolts for the install.
Oh yea, make sure no kids are within hearing distance when you install them. They might learn a whole new vocabulary otherwise...
Alex Barnes
Jan 24, 2015 10:21 PM
JasonD
Aug 23, 2010 03:14 PM
