LT install issue. Bolt hole needs tapped/threads cleaned up :(
Old Mar 28, 2004 | 10:24 PM
Kris93/95Z28's Avatar
Here is the issue, we have the Jet Hot headers in and they are ready to bolt up.. BUT the bolt holes on the #2 cylinder will thread in a few turns, and when pressure is applied, the bolts fall out.
I didn't break a bolt off in there I know this for sure!
A friend knows a guy who can clean the threads up with a tap.
Is it possible to do this with the head on the car, or will it most likely have to come off?
Old Mar 28, 2004 | 11:08 PM
IrocSS85's Avatar
there should be enough room to retap the bolt hole. problem will be make sure its straight. if he uses thread chasers, it shouldnt be a problem. but if he uses a tap, just be careful.
chris
Old Mar 28, 2004 | 11:13 PM
LS1_03's Avatar
The same thing happened with mine, except it was cylinder 7. After we tapped it, it was found to be just a lil chunk of metal. Took the air hose, blew it out. And everything was cake.
maybe2fast
Mar 16, 2015 09:45 AM
TitoPR221
Jan 29, 2015 08:00 PM
Joes96z
Dec 13, 2014 07:48 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
