LT install......do i remove the alternator bracket?
Old Jul 9, 2003 | 10:05 AM
got_hp?'s Avatar
ive removed everything so far (egr, air, stock ypipe, alternator, etc etc) except the two stock manifolds..............how the hell do i get a wrench/socket to these damn bolts?!!?!?!? i wanted to soak them overnight with PB Blaster, but i cant even see most of the damn bolts to shoot them with blaster.
for the passenger side, do i have to remove the alternator bracket?
the alternator is gone, but there is a small alternator mount that attached to the 1st header bolt.........it doesnt look like i can get to that bolt
how much of a PITA is removing the alternator bracket?
Old Jul 9, 2003 | 10:12 AM
GrdLockV6's Avatar
A fairly small ratchet with a u-joint attachment comes in real handy.
As for the alternator bracket, I removed it, I don't remember if I had to or not though. One thing, remember how it goes though. I couldn't figure out how the hell to put it back on so I just said screw it and left it off, alternetor is held in place good enough without it anyways.
Just keep at it man, took me two days to get my LT's installed. You're also gonna hafta remove the steering linkage and the starter as well, and you'll need to jack the car fairly high up in the air to slide the passenger side LT in through the bottom.
Old Jul 9, 2003 | 10:18 AM
revtime's Avatar
You do have the car on jackstands right?
Just wondering cause you get to most of them from the bottom.
I sprayed mine down with PB blaster and they soaked overnite.
As my high school Auto Tech teacher said "Any bolt can be reached with the proper combination of extensions and universal joints"
YEAH RIGHT!
Alternator bracket can come off and you can throw it as far from you as possible, it don,t need to go back on.
If you have a "Killer set of tools" you should be able to get to all the manifold bolts, just remember to take your time and make sure you are straight on the bolts when you loosen em, the last thing you want to do is break a bolt off in the head.
Old Jul 9, 2003 | 11:09 AM
speed76demon's Avatar
All i have is a craftsman tool set and i got them all. Just make sure you have a breaker bar handy b/c some are really hard to loosen and i spayed mine down for a week straight.
Old Jul 9, 2003 | 11:27 AM
got_hp?'s Avatar
well i just got all the passenger side bolts off within 15 mins, they were actually pretty damn easy to get off.......
except for the first one (closest to front)..........the damn alternator bracket is in the way........i cant even get a socket or wrench on it, there are too many other hoses and crap in the way..............did the rest of you guys all take the alternator bracket off too?
Old Jul 9, 2003 | 11:35 AM
treyZ28's Avatar
From: looking for a flow bench so Brook and I can race
dude- you have to remove everything as a good rule of thumb. I wouldn't be suprised if someone needed to take the spare tire out...
Old Jul 9, 2003 | 11:38 AM
got_hp?'s Avatar
bwhaha.........probably
i just wanted to avoid screwing with the bracket and all the pulley stuff on it.........oh well.........time to shower and goto work.......guess ill remove it tomorrow
Victor Lamb
Aug 26, 2017 02:52 PM
Red97LT1
Mar 1, 2015 05:08 PM
HectorM52
Jan 16, 2015 10:21 AM
squarehead
Nov 21, 2014 08:02 PM
