LT headers
Old Feb 5, 2008 | 12:40 PM
BlackBird9587's Avatar
LT headers
my headers keep coming loose! its really only the passenger side the most. just before i put it away for winter the two very bolts in the back came comepletley out twice. and then the gasket blows out making it sound like crap!! i use the blue locktight and it keeps happening. are there any locking bolts i could use or something??
Old Feb 5, 2008 | 12:56 PM
truedualws6's Avatar
They are expensive, but seem to be liked by those that use them.
>>split-lock fasteners<<
They used to be called Breslin but Percy's acquired Breslin a few month back.
Old Feb 5, 2008 | 02:11 PM
BUBBA's Avatar
Whatever you use, I advise 1". Also, should check them every so often, unless you really have some that are lockable----and easy to install and deinstall. I use ARP stainless and have had a couple back out, so I bought a couple extra to have on hand just in case. JMHO
Old Feb 5, 2008 | 06:09 PM
2000GTP's Avatar
Granted header bolts may be expensive, but in your situation, they might be well worth the money. My friend kept having the header bolts back out on his LS1 until one day they backed out enough where he blew out the gaskets. We installed some fresh gaskets and Stage 8 locking bolts and the car has been fine for almost 3 years now.
Old Feb 5, 2008 | 06:11 PM
GreasyB's Avatar
I used the 1" and I rarely have to tighten them. But I dont drive my car that often either. Is yours a DD?
Old Feb 5, 2008 | 10:08 PM
94formulabadbird's Avatar
I used the 1 inch bolts from arp after reading about them on here.I tightened mine after each of the 1st 2 heat cycles after installing my long tubes and they have been tight every time I have checked them since.Thats been almost a year now and 10k miles or so.Thats also using the copper gaskets that came with pacesetter longtubes.
Old Feb 5, 2008 | 11:29 PM
slomarao's Avatar
stage 8 locking bolts
Old Feb 6, 2008 | 12:19 AM
speed_demon24's Avatar
Loctite won't do anything on header bolts since heat breaks it down. Re-torque a few times after you heat cycle them and they should stay tight. Mine haven't needed to be retorqued once yet.
sherwinZ28
11
Aug 15, 2015 05:38 PM
colts0455
Jul 28, 2015 11:28 PM
jbc3
Jul 28, 2015 12:24 PM
Strick
Jul 14, 2015 07:28 AM
