Lt 4
Old Jul 29, 2003 | 05:41 PM
shootcallerz28's Avatar
Lt 4
I have chance to buy a 97 LT4 out of a 97 vette with less then 20,000 miles on it only the motor can i use my tranes out of my 93 z to work with this motor or will i have to get a 4l60e tranes i have a 700r4 let me know thanks.
Old Jul 29, 2003 | 05:59 PM
Dave Feerst's Avatar
well. You could use your 93 computer and have it tuned for the LT-4
Or you could use the LT-4 computer which would probibly work alot better, but im guessing it will not work correctly with either auto because I thought All LT-4s were stick.
Old Jul 29, 2003 | 06:00 PM
Zepher's Avatar
97 Vettes had the LS1. Maybe you mean 96 Vette since that was the year the LT4 was available from the factory.
Old Jul 29, 2003 | 06:11 PM
CamaroBoy96Z28's Avatar
LTx blocks are the same. Your tranny should bolt right up. The only real difference is the 4-bolt mains to the regular 2 the LT1s have.
I'm sure he meant 96 or at least I hope he did but the LT4 was available in 97 from the factory.....in the Firehawk and Camaro SS with a $40,000 price tag.
Old Jul 29, 2003 | 06:58 PM
LT4
I ment 96 a older guy has it and do not know what he has i can get the motor and computer for 1000.00 that is a steal for that motor thanks guys
Old Jul 29, 2003 | 07:14 PM
Zepher's Avatar
Might want to get the engine harness as well.
The fuel lines are routed different as well, you might wanna get an 94-97 LT1 F-body fuel rail, or use yours which should work.
