LT-1 Timing sets...
Old May 24, 2003 | 02:05 PM
  #16
GREGG 97Z's Avatar
Originally posted by Dave88LX
OK forgive my ignorance here. New to the LT1 scene
Is there and LT4, and also an LT4 Extreme Duty timing set?
Yes, most people choosing between these two seem to go with the ED since it's a lot stronger apparently and only $30 or so more. These are the two main choices for timing set upgrades from the stock one if you are not switching to an electric wp. The Cloyes roller requires you use an electric wp.
My stuff has 110K miles on it. If I got a new chain, do I need to replace the sprockets too? I don't know how much they wear down...
If you went with either of these set's you would need new gears as well. The only way you could just use a new chain is with the stock gears, but I wouldn't recommend doing that. If you are getting a new timing chain just go with the complete new timing set, with new gears too.
Old May 25, 2003 | 02:32 PM
  #17
ChvyCruzen's Avatar
What about the Lunati timing set that is offered by Summit. If I were to buy that, could I use my stock wp or would I need an electric?
Old May 25, 2003 | 04:01 PM
  #18
Don 97 SS's Avatar
I'd highly recommend the ED timing set, sure it costs a little more but seems to be much stouter that the LT4 or LT1 set. Also remember that there are two sprockets and one gear to be replaced the third one is the gear that drives the WP. Many times this is over looked. That WP gear is a wear item also.
And for what it is worth, I'm one guy that does not recommend the electric WP mod.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Sergio
Jan 27, 2016 04:27 PM
kksi
Feb 16, 2015 06:49 PM
sskevinm
Dec 18, 2014 11:16 AM
