LT-1 rocker and injector selection questions
Old 05-10-2003, 05:51 PM
Ryan 97 Ram Air T/A's Avatar
I'm getting ready to put on LT-4 heads and a CC-305 or similar cam. My questions involve how many new parts I will have to get when I make the switch.
Will the GMPP hotcam roller rockers work with the CC305 or will I have to get new ones? Also, will I be pushing the stock injectors and need to upgrade to 28#? I'm already planning on upgrading the fuel pump.
Any input is appreciated.
Ryan 97 Ram Air T/A is offline
Old 05-10-2003, 08:51 PM
96speed's Avatar
Your rockers will be fine. You could use the stock rockers.
Select injectors by figuring out how much power you'll make. Sounds like some 30#s might be right for you, but do a search for the injector calculator, and go from there. Or, try www.racetronix.com . Jack at RT is super helpful, and really knows his stuff.
Ryan
96speed is offline
Old 05-10-2003, 09:44 PM
yorkie's Avatar
28 # injectors...
I have 11 bosch injectors, need cleaning, caps, o rings- $80 delivered, have the cleaner pick the 8 best of the 11.
yorkie is offline
HectorM52
07-30-2017 11:46 AM
DirtyDaveW
12-01-2016 05:37 PM
oldschool
02-09-2016 09:21 PM
Sergio
01-27-2016 04:27 PM
12-17-2014 11:00 AM
Quick Reply: LT-1 rocker and injector selection questions
