LT-1 randomly dies.....
Old Aug 17, 2003 | 03:07 PM
1965GP's Avatar
Need some help guys. My car is randomly just dying. It usually happens at low rpm. I'll be driving and it will just cut out. When I try to start it it's like it has no spark, but if you play with the coil wire, it will start up, then die 100 ft down the road. So I replace the coil wire today and it is still doing it. The SES light hasn't come on yet, so I don't know where to start. I tried to get it scanned at Autozone and they said they couldn't scan it unless the car was OBD II. Any suggestions? I love the car, but I'm fed up with it.
Old Aug 17, 2003 | 03:19 PM
Dave19yz28's Avatar
opti, injectors, fuel pump, fuel filter, plugs, wires...could be a host of things.
Old Aug 17, 2003 | 03:29 PM
1965GP's Avatar
What gets me is that it's not happening all the time. I would think a most of those either work or not.
Old Aug 17, 2003 | 03:35 PM
96 WS6's Avatar
Did you think about replacing the coil itself? it's only 30 bucks and it won't hurt.
Old Aug 17, 2003 | 03:48 PM
1965GP's Avatar
If the coil was bad, wouldn't it be bad through all RPM ranges? If the car is running, I can take it above 2000-2400 and not have any problems at all. Your probably right though, it's only $30, I should just do it. Could this be the EGR valve? how hard is it to remove from the system? Is it worth it?
Old Aug 17, 2003 | 06:17 PM
94 Roadhog's Avatar
Here is something you may want to try, I was having the same
problem and while the car was idling in the driveway I started
wiggling wires , When I moved the wire that goes to the ICM
module the engine died , I restarted the engine and moved the
wire and same thing happened .
I adjusted the contacts on the plug and it lasted for 3 months and
started again. Finely soldered wires to the module and have not
had any more trouble.
Doesn't cost to try this either.
Dave B
Old Aug 17, 2003 | 08:38 PM
1965GP's Avatar
Sounds like a great idea. I'm new to the 4th gens, where is this on the car? I think it has to be something like this since it's so erratic.
Old Sep 2, 2003 | 08:43 PM
94 Roadhog's Avatar
Lt1 randomly dies
1965GP
Sorry I lost the thread and could not find it, someone showed
me how to locate it.
You have probably have found where its located by now, if not,
its located on a metal plate that the coil is mounted to, the icm
is setting just above the coil . Its a small black thingy with a
four wire plug on it , with the engine running just wiggle this
wire to see if its the trouble. ( coil and icm is on front of ds
head , just follow the coil wire from the opti)
Good luck, and let us know what you find.
Dave B
Old Sep 2, 2003 | 09:45 PM
You can find it here.
Nice car collection.
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
greenzee28
Sep 25, 2015 04:29 PM
Aaront810
Sep 11, 2015 11:24 AM
damnyankee36
Sep 9, 2015 07:06 PM
