LT-1 problem
Old Feb 1, 2006 | 11:33 AM
ScottZLT1's Avatar
LT-1 problem
i have a 1994 camaro and i just took off the under drive pullies because the car would drivw fine except when you got on it, then once it got to 60 it would shift to the next gear and it would stuter, so i took them off drove it around fine, even got on it and was fine. After storing it for a week or two i got it out and ran it to get stuff moving again. Tried driving it and it stuters and bucks everytime i want to excellerate, but it idels just fine. Any ideas????
Old Feb 1, 2006 | 11:34 AM
ScottZLT1's Avatar
Re: LT-1 problem
also i took off the 52mm throttle body
Old Feb 1, 2006 | 12:15 PM
Re: LT-1 problem
The under drive pullies had nothing to do with the engine stuttering. That's an ignition or fuel problem. When you swapped out the throttle body, is there any chance you dripped water on the Optispark distributor?
Old Feb 2, 2006 | 06:58 PM
ScottZLT1's Avatar
Re: LT-1 problem
no but i forgot about the radator fluid leaking because one of the screws on the bottom of the throttle body was broken and radiator fluid leaked out the bottom. Oh NO!!!!!!!!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Sergio
Jan 27, 2016 04:27 PM
kksi
Feb 16, 2015 06:49 PM
sskevinm
Dec 18, 2014 11:16 AM
