LT-1 Flow numbers vs.LE2 & LE3's & others
Old Jun 5, 2006 | 08:10 PM
RED396's Avatar
Here is what I have, a set of stock LT-1 heads proffessionaly ported and port matched to the intake and was approximately $600 less.
2.08 Intake
1.60 Exhaust
28" test Pressure
Lift I/ E/ % of Ex to In
.100 87 66 76%
.200 152 125 82%
.300 209 158 76%
.400 248 176 71%
.500 271 185 68%
.600 276 191 69%
.700 285 198 69%
AVG 73%
How do these numbers compare to others?
Old Jun 5, 2006 | 11:07 PM
user 647483's Avatar
Re: LT-1 Flow numbers vs.LE2 & LE3's & others
Where did ya get those?
Those definitely flow well, I wish that was all there was to getting performance out of heads.
Old Jun 5, 2006 | 11:37 PM
Javier97Z28's Avatar
Moderator
That's a fuggin huge intake valve on an LT1...
That being said these were my LE2 flow #'s with 2.00/1.56 valves
.2 139/109
.3 192/142
.4 241/170
.5 269/184
.6 274/195
.650 275/198
Old Jun 6, 2006 | 12:07 AM
89385formula's Avatar
I no longer have an LT1, but heres what my Blackstone heads flowed when they had the 2.02/1.6 valves. Just throwing the numbers in for comparisons sake. Exhaust numbers were flowed with a pipe. Numbers were also backed on other benches, and when the intake valve was upped to 2.05 they picked up some cfm across the board. I am not sure if i have those flow sheets though.
.1 74/64
.2 147/118
.3 203/167
.4 249/197
.5 269/214
.6 284/225
.7 287/232
Old Jun 6, 2006 | 07:19 AM
Sweetred95ta's Avatar
I didn't think you could get that big of valves in the stock LT1 castings. I was under the impression that 2.0/1.56 were about as big as you wanted to go. My heads were p&p and they flowed the numbers in my sig at .600 with no pipe.
Old Jun 6, 2006 | 09:22 AM
LE2 flow #'s with 2.00/1.56 valves (GM LT1 castings)
(not currently installed on my car)
Old Jun 6, 2006 | 09:50 AM
SStrokerAce's Avatar
.1 74/64
.2 147/118
.3 203/167
.4 249/197
.5 269/214
.6 284/225
.7 287/232
Kyle,
They only flowed 275cfm w a 2.055" valve on my bench.
Bret
Old Jun 6, 2006 | 11:56 AM
Originally Posted by SStrokerAce
Kyle,
Bret
Yeah i remember that now. Low and mid lift numbers were higher on your bench as well. No matter what a badass set of heads.
Old Jun 13, 2006 | 08:09 PM
504strokr's Avatar
I was told by Larry Meaux that the biggest valve you could get in the intake of the lt1 style head was 2.055. My lt4 heads flowed 285cfm @ .650 .
96 T/A Old set-up: lt4 heads& lt1 motorsports custom grind cam 11.4@118.00 w/700r4 & 9" 3.89 3400lb 390rwhp/ 412ft-lb tq
New Set-up: 396 afr220's, comp cam, 250@.050, th400 470rwhp tuned by geoff @ thunderracing 3,187 w/me in it.
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Roadie
Feb 16, 2015 10:34 AM
MadMav
Feb 6, 2015 11:02 PM
Red_94Formula
Jan 22, 2015 12:17 AM
