LT-1 Crank
Old Jul 8, 2005 | 06:29 PM
ZMAN Z28's Avatar
LT-1 Crank
I know the LT-1 and a regular old 350 cranks are different. Is there any visible way to tell?
I pulled my motor. Premptive rebuild. Good thing as the bearings were pretty worn, but not spun. The crank turned over just fine in the block. The crank appeared to be in great shape. My dad and I told the machine shop to only polish the crank. Today I go to the machine shop, and they told me they had to turn the crank 10/10. They did not call to tell me they were going to do work I did not authorize. I'm hoping they are not going to try to slip me a regular non LT-1 350 crank. So I would like to know how this will effect the clearances etc etc, or any other issues I might run into (this is if it is my LT-1 crank turned 10 under)?
Thanks for the advice:
ZMAN
Old Jul 8, 2005 | 06:57 PM
Z284thgen's Avatar
Re: LT-1 Crank
the main difference is the rear main seal area
if your crank looks different then this i would then be worried
crank
Old Jul 8, 2005 | 07:59 PM
ZMAN Z28's Avatar
Re: LT-1 Crank
If it looks different then that, then the shop better be worried. I don't really think they are trying to jack me around. I also don't have a great feeling either, especially they should have called.
ZMAN
Old Jul 8, 2005 | 09:13 PM
1racerdude's Avatar
Re: LT-1 Crank
Originally Posted by ZMAN Z28
ZMAN
Ya will be fine with 10-10 just make sure the brgs are 10-10 and check your clearances and get at LEAST Clevitte "H" series and cam brgs. They are a little more but a LOT better.
Rod=.0025-.0027
Maims=.0027-.0030
Cam=.0040
Ya have to get a GOOD oil pump with the 3/4" pickup to keep up with these clearances.Don't know what ya are building,but ya can go a LITTLE less maybe .0005 on rods and mains.Get a Melling or a GOOD name brand pump and a blueprinted one if ya can afford it with the pickup already installed.Get the plate that bolts under the pump to stop oil from climbing the back of the pan under acceleration($10.00) and DON'T leave out the baffle.
All of this is just GOOD insurance.
Old Jul 8, 2005 | 10:35 PM
ZMAN Z28's Avatar
Re: LT-1 Crank
Only building it to last another 100k miles. I'm not stroking or even going to bore it 30 over. Having the rods cut for new bolts, the block is boiled, new plugs and the oil galleys cleaned out, the block mic'd. New rings. There wasn't even a hint of a ridge in any of the cylinders. New cam bearings, rod and main bearings. Having a valve job done, heads milled, and cleaned. I'm changing my hot-cam to a 224/236 .535/.555 (1.6's) comp cam ground on a 112 lobe sep. So this car is my daily driver, even in the winter. Blizzak's are awesome.
Will the rear main seal housing fit or be the same as the one for a regular 350 crank?
ZMAN
Old Jul 8, 2005 | 10:38 PM
1racerdude's Avatar
Re: LT-1 Crank
ZMAN
Get the Clevitte brgs,do the correct clearances,and a good pump and it will last that next 100,000 miles.
Aug 18, 2015 07:08 AM
CARiD
Exhaust System
Aug 3, 2015 05:10 AM
1995Blackz28
Jul 20, 2015 09:34 AM
Catmaigne
Jul 14, 2015 05:17 PM
